PaSprinter24 Posted December 10, 2012 Share Posted December 10, 2012 Hey guys I wanna put a catch can on my leggy nd was wondering were the line goes into the inlet hose nd if any1 has any suggestions. Thanks Link to comment Share on other sites More sharing options...
Strizzy Posted December 10, 2012 Share Posted December 10, 2012 English. http://images.wikia.com/residentevil/images/2/20/ENGLISH_MOTHERFUCKER_DO_YOU_SPEAK_IT.jpg Do you speak it? And there is no need for a catch can, other than to cover up other issues. My bad luck build Link to comment Share on other sites More sharing options...
iNVAR Posted December 10, 2012 Share Posted December 10, 2012 And there is no need for a catch can, other than to cover up other issues. Link to comment Share on other sites More sharing options...
Strizzy Posted December 10, 2012 Share Posted December 10, 2012 Unless your tracking you car and pulling high G's on long swooping turns, then you don't need it with a properly working PCV system. My bad luck build Link to comment Share on other sites More sharing options...
iNVAR Posted December 10, 2012 Share Posted December 10, 2012 I want to disagree with that. A working PCV system merely vents gases back into the intake tract for combustion, for emissions purposes, but as a result the intake tract will get greased up. I guess on a stock boosted car it'd be fine, but even on a stage 2 which is running about 33% more boost (13.5 vs 18), it seems to me like there'd be a lot more blowby, enough to warrant installing a catch can. Link to comment Share on other sites More sharing options...
PaSprinter24 Posted December 11, 2012 Author Share Posted December 11, 2012 Yah I would think ud wanna prolong the lives of our turbos but that's just me. My question still stands, were is the line goin onto the inlet hose or were is it comin off the valve cover? Invar thank you for bein mature nd helpfull Link to comment Share on other sites More sharing options...
Strizzy Posted December 11, 2012 Share Posted December 11, 2012 To do a proper catch can setup in our cars, you would need two of them. One connected to the vent hoses coming from the valve covers, and one connected to the PCV assembly. Also: http://www.iwsti.com/forums/2-5-liter-litre-factory-motor/146699-official-sti-engine-venting-o-separators-catch-cans-thread.html My bad luck build Link to comment Share on other sites More sharing options...
iNVAR Posted December 11, 2012 Share Posted December 11, 2012 ^-- +1 And don't be tempted to take a shortcut and use one can for both the valve covers and the crankcase... You do not want the two interconnected like that. Link to comment Share on other sites More sharing options...
Aracheon Posted December 11, 2012 Share Posted December 11, 2012 *Cracks knuckles* There are better things to spend your money on than catch cans, but, having decided to run them myself, having read through the MASSIVE IWSTI thread about them in its entirety, and having redone my dual-can setup several times, let me toss in my $0.02. - Whatever setup you go with, make certain that the can has a filtering/separation media in it of some kind. (I'm using the Moroso offering designed for the STi.) - The cans will catch water vapor. If you live in a colder climate, make sure that you mount the cans somewhere in the engine bay where they'll stay warm, and also drain them regularly. - If you're going to spend the time and money to do this, do it right the first time and make sure you have a separate can for the head breathers, and a separate can for the crankcase. - Also, for maximum efficiency, it wouldn't hurt to have a dual vacuum source for at least the crankcase can. I'm using a Toyota Supra check valve from a vacuum source on the back if the intake manifold for vacuum, and then a line off of the inlet tube for boost vacuum. To answer your original question, there are several nipples on the inlet tube. Trace to the one that the original PCV system uses. My crankcase can uses the one that's closest to the turbo. Link to comment Share on other sites More sharing options...
