HeroofCanton Posted April 14, 2013 Share Posted April 14, 2013 I'm in the market for a good performance coilpack for my 1997 Legacy L. 2.2l. Bought an MSD coilpack but it looks to me like it doesn't fit at all. If anyone can point me in the right direction it'd be greatly appreciated. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 14, 2013 Share Posted April 14, 2013 /thread. Link to comment Share on other sites More sharing options...
Baddog Posted April 18, 2013 Share Posted April 18, 2013 Heads up. My MSD failed after 4 years. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 18, 2013 Share Posted April 18, 2013 was the performance gain enough to make it worth replacing? Link to comment Share on other sites More sharing options...
cal71919 Posted April 18, 2013 Share Posted April 18, 2013 I've read on several srt forums that the OEM srt 4 coil pack is more reliable than the msd unit. I'm going to do more research on that before I pull the trigger on that upgrade. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted April 18, 2013 Share Posted April 18, 2013 was the performance gain enough to make it worth replacing? $75 every 4 years? I'd say, "hell yeah". The only issue w/99s+ is that the ECU will sense the increased fuel burn & add more fuel to "correct" it. 98 ECUs do this too but the correction isn't nearly as severe. Link to comment Share on other sites More sharing options...
pleaidestar Posted April 18, 2013 Share Posted April 18, 2013 4 years of service is pretty good for an aftermarket electrical part, msd is a good coilpack. The gains in fuel efficiency alone will keep one under the hood of my car whether I have to replace it every four years or not. You can't spend 80 bucks on one part and expect a 10 hp or 10 mpg raise, just not going to happen. Imo its the best 80 dollars I spent in the last year. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 18, 2013 Share Posted April 18, 2013 Great im a 99+ So is the MSD not as affective? Or should I start using 91 or something so the ecu knows it wont pre detonate with increased spark? Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted April 18, 2013 Share Posted April 18, 2013 Great im a 99+ So is the MSD not as affective? Or should I start using 91 or something so the ecu knows it wont pre detonate with increased spark? The MSD will still retain its effectiveness but you will lose an MPG or so with the bright side of a more responsive & linear power delivery as the fuel delivery increases to match the spark delivered. 91 is probably a little excessive. You're fine on 87. I've been using it the whole time & nothing bad has happened or will happen. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 18, 2013 Share Posted April 18, 2013 Oh nice. Im down for only power gain. That's what overtime is for, buying gas to burn! Haha Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 18, 2013 Share Posted April 18, 2013 Its strange because I've never had the car respond the way its supposed to when you reset the ECU. I remember a while ago you had told me how to do it. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted April 18, 2013 Share Posted April 18, 2013 Its strange because I've never had the car respond the way its supposed to when you reset the ECU. I remember a while ago you had told me how to do it. Oh it responded but now you probably have a more linear power delivery. I know my ECU responded immediately & I felt the low end kick up a bit. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 18, 2013 Share Posted April 18, 2013 I haven't done this mod yet. Im just talking in terms of resetting the ecu... Isn't it supposed to ramp up to 2k and settle down gradually? If so, mine never did that.. Link to comment Share on other sites More sharing options...
pleaidestar Posted April 18, 2013 Share Posted April 18, 2013 Its strange because I've never had the car respond the way its supposed to when you reset the ECU. I remember a while ago you had told me how to do it. That's interesting about resetting ecu..how is that done, I still haven't had a chance to hook my car up to a scanner to clear my codes from that misfire, I'm sure the egr code is pending because of the delete, but I never knew an ecu reset could be done. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 18, 2013 Share Posted April 18, 2013 unhook the battery, hold the brakes for a bit to purge the built up power, let the car sit without a battery for an hour or so, done Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 18, 2013 Share Posted April 18, 2013 Like depress brakes and hold? I tried that, I wonder if my car is different because of the lack of MAF goofiness... Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 18, 2013 Share Posted April 18, 2013 Ill give it a shot again.. worst that could happen is nothing. Link to comment Share on other sites More sharing options...
Zues Marine Posted April 18, 2013 Share Posted April 18, 2013 well, you're just holding the brakes to turn on the lights and get the built up power out of the system, you could charge your iphone or whatever too technically or just pull the battery and let it sit overnight Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 18, 2013 Share Posted April 18, 2013 Ahhhhhhh I see, sounds good. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted April 18, 2013 Share Posted April 18, 2013 Its strange because I've never had the car respond the way its supposed to when you reset the ECU. I remember a while ago you had told me how to do it. Unhook the negative terminal. Depress the brake pedal for about 30 "Mississippi" seconds. Leave battery unplugged for about 1-2hrs. Plug back up negative terminal & start car. It should shoot up to 1800-2000rpms & then come down gradually to idle again. Reset complete. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 19, 2013 Share Posted April 19, 2013 That's what I thought... I want to know if my ecu is the same regardless of the fact it is speed density.. Or why my car is speed density..? Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted April 19, 2013 Share Posted April 19, 2013 That's what I thought... I want to know if my ecu is the same regardless of the fact it is speed density.. Or why my car is speed density..? The same as what? Phase 1 ECUs? The ECUs for the Phase 2 engines learn more, faster than those of the Phase 1s. They're also more restrictive as they will literally try to learn around changes to spark, air, & fuel. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 19, 2013 Share Posted April 19, 2013 If my ecu is the same as a phase 2 with a MAF. I have no MAF and it has a MAP sensor on the drivers side of the TB Link to comment Share on other sites More sharing options...
pleaidestar Posted April 19, 2013 Share Posted April 19, 2013 unhook the battery, hold the brakes for a bit to purge the built up power, let the car sit without a battery for an hour or so, done That's it huh? Sweet thanks. Link to comment Share on other sites More sharing options...
