superbro Posted July 28, 2013 Share Posted July 28, 2013 Can somebody please post links to some threads that are good to read for a new owner? Just general information for someone planning to mod the car cosmetic and performance wise. And some just 'good to know' info about the car. Much appreciated. Link to comment Share on other sites More sharing options...
adreyna Posted July 28, 2013 Share Posted July 28, 2013 Looking thru all the stickies for each 4th gen subjection is a good way to start. Also people have build threads on the photo sections and gives you an idea of what people are doing with their cars. Lastly just go thru this forum, and the other 4th gen forums clicking on every thread and each will give you a different info and views about these cars problems, solutions, and mods. Link to comment Share on other sites More sharing options...
zanzabar Posted July 29, 2013 Share Posted July 29, 2013 when you get the timing assembly done at 110k (or now if it has not been done and has more,) make sure that that the banjo bolt in the drivers side head gets cleaned, and make sure that the banjo on the turbo has the filter removed. the bolt on the head is to make sure that the AVCS sensor stays clean, and it runs around $1500 to get the bolt taken care of (basically the same as the timing assembly.) for mods, get a catless up pipe, so your turbo wont die from cat flake. get a pro tune if you have a tuner in your area instead of the access port if you have to pick. Link to comment Share on other sites More sharing options...
idiot4hire Posted July 29, 2013 Share Posted July 29, 2013 Change your diff and trans fluid. Use good motor oil like rotella t6 stay away from mobile one. Get a oil analysis from black stone labs. Check your control arms bushings they wear out and make noise. As far as mods for power a uppipe and stage one tune. Handling good tires and rsb open the car up a lot. Keep some money in the bank for wheel bearings. Other then that have fun with it unless you put a "illest" sticker on it in which case I hope it explodes. Link to comment Share on other sites More sharing options...
06legsleeper Posted July 29, 2013 Share Posted July 29, 2013 ^^^ illest sticker .... totally agree .... rotella is def the way to go ... and the first thing i did was got rid of the uppipe.. its a time bomb waiting to mess up your shit lol .. then all the mod bugs got me .. now its a list of stuff done lol you can get a reg sti up pipe. doesnt have to be anything special good luck and enjoy Link to comment Share on other sites More sharing options...
PtPixel Posted July 29, 2013 Share Posted July 29, 2013 Just look at the sticky in this forum - the new member introductions - called " ATTN: New Members! Look here first." Has basically all of the basic info there. Link to comment Share on other sites More sharing options...
superbro Posted July 29, 2013 Author Share Posted July 29, 2013 Just look at the sticky in this forum - the new member introductions - called " ATTN: New Members! Look here first." Has basically all of the basic info there. Right on thanks Link to comment Share on other sites More sharing options...
