adreyna Posted January 20, 2012 Share Posted January 20, 2012 Hey So last night trying to enjoy Seattle's Snow Strom I went out to do a couple donuts and drift a bit in a safe confined parking lot. I thought it was no biggy cause ive done them before in snow in multiple cars. When I was done I had a burn smell coming in to the cabin but I just thought it might of been the tires. I drove away and noticed my car was trembling at a stop light. I drove for a bit then it turned off on me. I wasn't able to start it again. But in the "on" position I notice the fans were on full blast I thought I might of overheated to turbo since I was doing the donuts in 1st Gear revving it a bit high. After the fans turned off I tried cranking it a bit more and it won't turn over. I tried it acouple more times but by now I think I might of drained the battery. I have a 2005 LGT 5EAT. I replaced the turbo about 1500 miles ago. I did have the steering wheel at lock acouple times (I was reading it messed up your power stearing, but why doesn't it start?) I had acouple ppl help me push it into a parking lot. I'm about to walk over right no to see if I can start it again. My question is why won't it turn over? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 20, 2012 Share Posted January 20, 2012 The smell is common when doing that. It's been talked about before. I have no idea why the car won't turn over. On one has had that happen after donuts. I tried a few today in the parking lot at work, but there wasn't enough snow, too many tire tracks in it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
adreyna Posted January 20, 2012 Author Share Posted January 20, 2012 Well I'm try to go Jump Start it right now I just hope that fixes it. :/ Link to comment Share on other sites More sharing options...
Max Capacity Posted January 20, 2012 Share Posted January 20, 2012 It's a 05 have you ever replaced the battery ? You need to keep the terminals clean and put some grease over them to seal out moisture. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
adreyna Posted January 20, 2012 Author Share Posted January 20, 2012 I just pulled out the dip stick and it has no oil. Link to comment Share on other sites More sharing options...
rob-2 Posted January 20, 2012 Share Posted January 20, 2012 When was the last time you checked your oil? Link to comment Share on other sites More sharing options...
jazzymt Posted January 20, 2012 Share Posted January 20, 2012 I just pulled out the dip stick and it has no oil. It's possible it's just too low to read, but - that can't be good. First order of business is to do an oil change & see how low it really was. Then try to jump start it - if it doesn't budge, it might be siezed... [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
PearlBlueGT Posted January 20, 2012 Share Posted January 20, 2012 Hope you didn't blow your engine, which I think is what happened. No oil = rod bearings are gone. Link to comment Share on other sites More sharing options...
adreyna Posted January 20, 2012 Author Share Posted January 20, 2012 I think it's a rod knock Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted January 20, 2012 Mega Users Share Posted January 20, 2012 there needs to be a sticky in every section saying to check your oil because these cars burn it. sorry to hear about that "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
bmx045 Posted January 20, 2012 Share Posted January 20, 2012 any time a turbo blows it usually contaminates the oil and destroys your engine rod bearings at the same time, within 5k miles of turbo replacement you might hear engine rod knock. So what you're describing of a blown engine is pretty normal. Link to comment Share on other sites More sharing options...
adreyna Posted January 20, 2012 Author Share Posted January 20, 2012 I guess that's what I'm looking at right now. I'm at an auto shop right now. They cant look at it till Monday but it sounds like a blown engine. He said it could be a jumped time. He needs a good look but it sounds bad. Link to comment Share on other sites More sharing options...
adreyna Posted January 20, 2012 Author Share Posted January 20, 2012 Engine Rebuild? Or Sti conversion? Link to comment Share on other sites More sharing options...
boymk123 Posted January 20, 2012 Share Posted January 20, 2012 if you could not check your oil before doing a donut, why bother with sti conversion? sell your cah Link to comment Share on other sites More sharing options...
bmx045 Posted January 20, 2012 Share Posted January 20, 2012 convert to a bicycle Link to comment Share on other sites More sharing options...
boymk123 Posted January 20, 2012 Share Posted January 20, 2012 Martin bicycle Link to comment Share on other sites More sharing options...
jmorris6689 Posted January 21, 2012 Share Posted January 21, 2012 STi conversion isnt cheap FYI Link to comment Share on other sites More sharing options...
compsurge Posted January 21, 2012 Share Posted January 21, 2012 OP, FYI EJ257 shortblock != STi conversion. $1600ish is a new block from Heuberger (subarupartsstore.net). You want the EJ257 OEM shortblock, transfer everything over from the old motor and put it in. New gaskets everywhere, new banjo bolt filters, replace all old hoses, etc. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted January 21, 2012 Share Posted January 21, 2012 if you could not check your oil before doing a donut, why bother with sti conversion? sell your ORGANS Link to comment Share on other sites More sharing options...
boymk123 Posted January 21, 2012 Share Posted January 21, 2012 thanks Link to comment Share on other sites More sharing options...
ericem Posted January 21, 2012 Share Posted January 21, 2012 The smell is common when doing that. It's been talked about before. I have no idea why the car won't turn over. On one has had that happen after donuts. I tried a few today in the parking lot at work, but there wasn't enough snow, too many tire tracks in it. went out right now I do smell it. I hope it's not center diff clutches melting Definitely smells like tires though. If you're running snow tires it will catch asphalt if it's not deep enough. Link to comment Share on other sites More sharing options...
wpgspecb Posted January 21, 2012 Share Posted January 21, 2012 wow Link to comment Share on other sites More sharing options...
goneskiian Posted January 21, 2012 Share Posted January 21, 2012 Put this in it! http://legacygt.com/forums/showthread.php/some-body-buy-now-178278.html Diesel FTW!!! Link to comment Share on other sites More sharing options...
murderDOCkill Posted January 22, 2012 Share Posted January 22, 2012 Did a couple donuts the other night but the snow was light and only a few inches. Had the similar tire smell on my final turn. A little worried as I've dealt with the turbo/engine nightmare before. Checked my PS fluid in the am and it was actually below cold min. oil level was ok. antifreeze low. topped off my fluids and everything seems to be ok. if you fried a bearing bring on a new shortblock. stealership could be a $5000+ investment. i also think i'm done with these parking lot donuts as i have a helluva time getting all the snow off the rims. nothing gets me more irked than having to pull over three times on the way to work to try and clear out the snow. #lgtproblems Link to comment Share on other sites More sharing options...
adreyna Posted January 23, 2012 Author Share Posted January 23, 2012 Thanks guys for a your input. A bike? Naw I cant I travel thru the pass a lot in need awd. Well at this point idk what it can be. The auto shop I took it to is gonna check it out by tomorrow that way I at least know what I got my self in to. Link to comment Share on other sites More sharing options...
