atfarris Posted October 1, 2013 Share Posted October 1, 2013 I went to put a radio in my car, so I searched for a face plate mounting kit. I found this-http://www.bestbuy.com/site/scosche-stereo-installation-kit-for-select-subaru-vehicles/7200389.p?id=1218019616088&skuId=7200389 (notice 1st review on this one) and this-http://www.carid.com/1990-subaru-legacy-stereo-installation/metra-stereo-dash-kit-4481418.html neither of them look like they would fit, the stock faceplate is long and slants on the bottom. And in the best buy review, the guy says it wouldn't fit his wagon. I could not find any more, so I made my own. heres a how-to with pics First, I took the radio face plate out and traced the double-din square onto a piece of 1/4" plexiglass. I then cut the plexiglass square out, and fit it into the faceplate Link to comment Share on other sites More sharing options...
atfarris Posted October 1, 2013 Author Share Posted October 1, 2013 Next I masked the front, so the glue would not seep through to the front, causing more sanding. I Used a 2 part CA glue, one formulated for plastics. Very strong stuff. I put a couple of beads all around the back Link to comment Share on other sites More sharing options...
atfarris Posted October 1, 2013 Author Share Posted October 1, 2013 After that I took the single din radio mounting sleeve, and traced it where I wanted it. I used a scroll saw to cut it out. I believe a cutting wheel would be best for this application, even on a dremmel tool. Plaxiglass is hard to cut, just because it melts right back together after your saw blade passes through. Link to comment Share on other sites More sharing options...
atfarris Posted October 1, 2013 Author Share Posted October 1, 2013 I used spot putty to fill in the gaps. Bondo would probably fill in better, but this is easy to sand. I did this 2 times, just to make sure it was smooth. Link to comment Share on other sites More sharing options...
Evnldr Posted October 1, 2013 Share Posted October 1, 2013 IIRC I used a fine metal blade to cut Lexan. Link to comment Share on other sites More sharing options...
atfarris Posted October 1, 2013 Author Share Posted October 1, 2013 and then paint. you can see the seams in the picture, its barely noticeable in person. I also only got 1 coat of paint on it, It was near the end of the can. Another way to cover it would be brush on bed liner. Looks good, and it would cover up any voids. Note-I did cut 2 triangle braces out of plexiglass to hold up the radio sleeve. I just glued them in. Pretty easy to do, it just took a piece of plexiglass, glue, spot putty and paint. Link to comment Share on other sites More sharing options...
Zues Marine Posted October 1, 2013 Share Posted October 1, 2013 that looks like shit bro Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted October 1, 2013 Share Posted October 1, 2013 Pretty ingenious Link to comment Share on other sites More sharing options...
Evnldr Posted October 1, 2013 Share Posted October 1, 2013 Why not get the correct mounting kit?.. or use ABS Link to comment Share on other sites More sharing options...
lockmedic Posted October 1, 2013 Share Posted October 1, 2013 You can toss that mounting sleeve and just use the OEM radio brackets. . . and an OEM pocket or two below it. No kit required. . .which is probably why they don't sell one. Clever, tho. Link to comment Share on other sites More sharing options...
stevenva Posted October 2, 2013 Share Posted October 2, 2013 "No kit required. . .which is probably why they don't sell one." That is exactly why they don't sell one. It is called an ISO mount. You use the factory brackets. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted October 2, 2013 Share Posted October 2, 2013 Some gauges and switches would have looked better on it if you llaced the head unit lower Link to comment Share on other sites More sharing options...
pleaidestar Posted October 2, 2013 Share Posted October 2, 2013 Bummer, sucks to get no love on a project you took some time on, put some of that product knowlegde and molding into something that isn't trivial or un-needed.when your doing work like that you should want it to be an important part or a focal point. It looks like from the pics of the dash your working with a 1st gen legacy..I love them myself, I think they are great looking cars but with little to no body modification support...so its up to the consumers talent to think up what no one else in the past 20 years has. Nice dedication though. Link to comment Share on other sites More sharing options...
