edkwon Posted August 10, 2008 Share Posted August 10, 2008 Both my 08 remote keys are dying and i want to get the replacement batteries first, then open up my keys and replace them. Link to comment Share on other sites More sharing options...
Adamaxus Posted August 10, 2008 Share Posted August 10, 2008 2025 i believe. one per remote. Link to comment Share on other sites More sharing options...
Wang Lung Posted August 10, 2008 Share Posted August 10, 2008 CR 1620. Just replaced mine. Be careful with that little screw that holds the key together. I lost one. Found one in an eyeglass repair kit that works. Link to comment Share on other sites More sharing options...
edkwon Posted August 10, 2008 Author Share Posted August 10, 2008 CR 1620. Just replaced mine. Be careful with that little screw that holds the key together. I lost one. Found one in an eyeglass repair kit that works. Thanks much. Link to comment Share on other sites More sharing options...
fweasel Posted August 10, 2008 Share Posted August 10, 2008 The key FOB doesn't have the replacement part number stamped on the back? The ones for our 05 and 06 cars do. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Wang Lung Posted August 11, 2008 Share Posted August 11, 2008 The key FOB doesn't have the replacement part number stamped on the back? The ones for our 05 and 06 cars do. The battery model number is molded into the inside of the key. It does indicates which way the battery is to load, in case you forget, like I did. Link to comment Share on other sites More sharing options...
Adamaxus Posted August 11, 2008 Share Posted August 11, 2008 CR 1620. Just replaced mine. Be careful with that little screw that holds the key together. I lost one. Found one in an eyeglass repair kit that works. that's weird, i just replaced mine and it was definitely a 2025. Do we get different remotes or some jazz because we are canadian? Link to comment Share on other sites More sharing options...
edkwon Posted August 11, 2008 Author Share Posted August 11, 2008 that's weird, i just replaced mine and it was definitely a 2025. Do we get different remotes or some jazz because we are canadian? 05-07 key fobs are separate from the keys while 08+ have the remote integrated into the key, thats why i specified because i dont know if the separate older key fobs have different batteries from the new integrated fob+key units Link to comment Share on other sites More sharing options...
