Dominyc123 Posted May 29, 2009 Share Posted May 29, 2009 I gutted my DP and I was wondering if using Spark Plug non-foulers would help eliminate CEL. Below is the link with instructions, however it's for WRX. I guess my real question is if LGT has the same O2 sensor as WRX. Thank you for the help http://forums.nasioc.com/forums/showthread.php?t=1473769&highlight=help+drill+fix Link to comment Share on other sites More sharing options...
byronchrisp05 Posted May 29, 2009 Share Posted May 29, 2009 did it on my car when i installed my dp last weekend and havent had the cel on yet Link to comment Share on other sites More sharing options...
Dominyc123 Posted May 29, 2009 Author Share Posted May 29, 2009 Thanks Link to comment Share on other sites More sharing options...
alaskajoel Posted May 29, 2009 Share Posted May 29, 2009 This does work, but most people who gut a cat only do the first DP cat and leave the second in the DP. If you just gutted the shorty like most do, you should not have a CEL. (anti-foulers on LGT) http://www.legacygt.com/forums/showthread.php?t=106398&highlight=p0420 Link to comment Share on other sites More sharing options...
Dominyc123 Posted May 29, 2009 Author Share Posted May 29, 2009 Thanks, So far I just gutted the first section of DP, I was thinking doing the second one as well. Why most people leave the second part untouched? Any disadvantages to that? Link to comment Share on other sites More sharing options...
rtbrjason Posted May 29, 2009 Share Posted May 29, 2009 I gutted the first cat only on my 08 specb. After about 30 or so miles of driving sure enough CEL and code 420 for cat efficiency. Best bet imo is to get a tactrix cable or accessport. Not only will that resolve the cel, but also will allow you to tune for better performance. Link to comment Share on other sites More sharing options...
alaskajoel Posted May 29, 2009 Share Posted May 29, 2009 I gutted the first cat only on my 08 specb. After about 30 or so miles of driving sure enough CEL and code 420 for cat efficiency. You have no Up Pipe Cat. 2005-2006 will not get the CEL...i don't know what year OP has. The second DP cat is not very restrictive, and is usually left to help eliminate the catless smell. You may leave 3-5 hp on the table but it's much more livable stink wise with the 2nd dp cat in tact. Link to comment Share on other sites More sharing options...
MindzEyeWRX02 Posted May 31, 2009 Share Posted May 31, 2009 Best bet imo is to get a tactrix cable or accessport. Not only will that resolve the cel, but also will allow you to tune for better performance. For engine management If you gut the second and third cat, get the car tuned for it. Even gutting the second cat changes the variables of your car a bit. Although if you were to get a protune you can get a lot more out of the car . With these cars engine management is your best friend. Just my 2 cents Link to comment Share on other sites More sharing options...
