Chubien Posted February 7, 2010 Share Posted February 7, 2010 There seems to mixed opinions if injector upgrade is really necessary for this turbo. I'm not at high altitude and live in a fairly cold climate.Supporting mods would be full exhaust, AVO TMIC and pannel filter. I would prefer not to do injectors if it's not absolutely necessary but at the same time I do want to most out of the VF52. I want to plan this ahead since this work will likely be done at EFI logics and they are a 7 hour driving distance for me.EFI's advice was to do injectors in order to play it safe and avoid a second trip to their facility but did state they would normally not suggest bigger injectors for a VF52 swap. Link to comment Share on other sites More sharing options...
kb2spn Posted February 7, 2010 Share Posted February 7, 2010 Definitely need injectors for the top end,my tune is capped at about 5500 rpm because of the injectors which will be install with fuel pump in the spring.Link me up whenever you are going to EFI. Link to comment Share on other sites More sharing options...
lucas569 Posted February 7, 2010 Share Posted February 7, 2010 what size injectors are on the wrx? Link to comment Share on other sites More sharing options...
Chubien Posted February 7, 2010 Author Share Posted February 7, 2010 I'm not sure what size the WRX injectors are but I do know that 07+ LGT's have improved fueling which gives a bit more margin over the 05-06 MY. Link to comment Share on other sites More sharing options...
EFI Logics Posted February 7, 2010 Share Posted February 7, 2010 There seems to mixed opinions if injector upgrade is really necessary for this upgrade. I'm not at high altitude and live in a fairly cold climate. Supporting mods would be full exhaust, AVO TMIC and pannel filter. I would prefer not to do injectors if it's not absolutely necessary but at the same time I do want to most out of the VF52. I want to plan this ahead since this work will likely be done at EFI logics and they are a 7 hour driving distance for me. EFI's advice was to do injectors in order to play it safe and avoid a second trip to their facility but normally they would not recommend the injector upgrade for a VF52 swap. We typically do not suggest injectors on this combination, but because of the distance you are traveling we want to make sure you do not run into any road blocks come time to tune the car. We typically give people who are driving long distances more of a cautionary suggestion list because we want them to be 100% on their long distance trip. Thanks, Chris Link to comment Share on other sites More sharing options...
m sprank Posted February 7, 2010 Share Posted February 7, 2010 He has top feed injectors already. He can get away with stock fueling on this set up. He will just lose a small amount on the top where there is no real power from a VF-52 anyway. For all intents and purposes stock fueling (with top feeds) is fine. Link to comment Share on other sites More sharing options...
Chubien Posted February 8, 2010 Author Share Posted February 8, 2010 We typically do not suggest injectors on this combination, but because of the distance you are traveling we want to make sure you do not run into any road blocks come time to tune the car. We typically give people who are driving long distances more of a cautionary suggestion list because we want them to be 100% on their long distance trip. Thanks, Chris If the car can get tuned with the stock injectors I would prefer to go that way. If skipping injector upgrade only means loosing very slightly up on top this is acceptable to me, as long as a safe tune can be achieved. Thanks for the input Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted February 8, 2010 Share Posted February 8, 2010 He has top feed injectors already. He can get away with stock fueling on this set up. He will just lose a small amount on the top where there is no real power from a VF-52 anyway. For all intents and purposes stock fueling (with top feeds) is fine. Side feeds are actually safer to run at higher duty cycles (assuming they are the same size as the top feeds) because the fuel flows through the injector body and cools the solenoid coil. I thought the OEM top feeds and side feeds were the same size? On the search for a new DD... Link to comment Share on other sites More sharing options...
lucas569 Posted February 8, 2010 Share Posted February 8, 2010 i think they run 10cc more but don't quote me on it! Link to comment Share on other sites More sharing options...
m sprank Posted February 8, 2010 Share Posted February 8, 2010 Side feeds might be safer to run, but are a little less efficient by design. Top feeds are 540cc (?) and support the VF-52 better than the side feeds. Top feeds are on the WRX stock too. Like I said, either way, the VF-52 can be used with stock fueling. Boost is just limited by maybe 2-3lbs at the very top end. The VF-52 does not hold the top well anyway, the major gains are down lower. Not trying to debate injectors, just answering the OP's question as honestly as possible without getting technical. Link to comment Share on other sites More sharing options...
DHL1010 Posted February 8, 2010 Share Posted February 8, 2010 I am running stock injector with VF52 on my '07 Legacy GT. And its doing 89% IDC with RON98 at sea level. The power curve for IHI VF52 turbo tappered down after 5500rpm. Link to comment Share on other sites More sharing options...
wpmarky Posted February 9, 2010 Share Posted February 9, 2010 DHL, do you have an airboy dynosheet that you can share? Link to comment Share on other sites More sharing options...
DHL1010 Posted February 9, 2010 Share Posted February 9, 2010 Not sure what is an airboy dyno sheet..... but I got my dyno graph. Link to comment Share on other sites More sharing options...
wpmarky Posted February 10, 2010 Share Posted February 10, 2010 looks like 250/320? interesting... what altitude are you at? Link to comment Share on other sites More sharing options...
DHL1010 Posted February 10, 2010 Share Posted February 10, 2010 Is it too low?? I can get higher? I am at sea level. Link to comment Share on other sites More sharing options...
lucas569 Posted February 10, 2010 Share Posted February 10, 2010 Is it too low?? I can get higher? I am at sea level. do u have auto or mt? Link to comment Share on other sites More sharing options...
wpmarky Posted February 10, 2010 Share Posted February 10, 2010 I thought at sea level, stg. 2 averages 250/280, and vf52 hits 280/320. Now I wonder if the stock injectors/pump are keeping you from 30hp? Or did you ask for a tune for more tq? Link to comment Share on other sites More sharing options...
DHL1010 Posted February 10, 2010 Share Posted February 10, 2010 do u have auto or mt? I am on stock auto 5-speed gear box... Link to comment Share on other sites More sharing options...
DHL1010 Posted February 10, 2010 Share Posted February 10, 2010 I thought at sea level, stg. 2 averages 250/280, and vf52 hits 280/320. Now I wonder if the stock injectors/pump are keeping you from 30hp? Or did you ask for a tune for more tq? I am on stock injectors and up-graded fuel pump..... Not sure how to squeeze out more power from this VF52. Link to comment Share on other sites More sharing options...
wpmarky Posted February 11, 2010 Share Posted February 11, 2010 If you send your injectors to witchhunter.com, they can modify them to 800cc or more for $100. You should be able to get some more power from that, which is what I'm planning to do as well. Link to comment Share on other sites More sharing options...
DHL1010 Posted February 11, 2010 Share Posted February 11, 2010 But my tuner told me changing injectors will not get anymore power as I am currently as 89% IDC of my stock injectors. Link to comment Share on other sites More sharing options...
Spec B Posted February 18, 2010 Share Posted February 18, 2010 ^ Either your tune is super conservative or your tuner has no clue what he is talking about...the VF52 will easily outflow your stock injectors at sea level. Really easily...unless you are running meth/water injection. Link to comment Share on other sites More sharing options...
Spec B Posted February 18, 2010 Share Posted February 18, 2010 With a VF43 (essentially the same size as a vf52 but in STI fitment) I was out of injectors (110% IDC) at 5000 rpm.. Link to comment Share on other sites More sharing options...
DHL1010 Posted February 18, 2010 Share Posted February 18, 2010 Thanks for your advise... Will check with my tuner again. Link to comment Share on other sites More sharing options...
Spec B Posted February 18, 2010 Share Posted February 18, 2010 Good luck..I have a feeling based on the tune you have you do not need larger injectors. But with injectors and a revised tune I am guessing you could gain a good 15-25hp on the high end. Link to comment Share on other sites More sharing options...
