Deadleave Posted December 21, 2010 Share Posted December 21, 2010 I ace a ERZ catted DP for auto. After a nasty scape I decided to check how low the DP sits, and it is the lowest part if the whole car. It sits about 3" above the ground. I have hit rocks, debris on the street etc.... But drove over and hit a raised manhole cover, which flattened a section of it and cracked a weld on the DP to exhaust flange. I'm don't think I'm slammed or such, konis on epic springs. Anyone think it's the pipe or just bad fitment on my car? Anyone else experience this, with erz or other brand? I heard perrins stay close to the frame rails. Link to comment Share on other sites More sharing options...
m sprank Posted December 22, 2010 Share Posted December 22, 2010 I have installed tons of these DP's. Rarely if ever do I see one hit. It takes a nasty bottom out or road debris to hit them. I have seen all pipes hit in some way. Race tracks do that. So do sharp hills. Or compressed air bottles on the road. My advice to you is slow down. You might be driving too fast for road conditions. Link to comment Share on other sites More sharing options...
Deadleave Posted December 22, 2010 Author Share Posted December 22, 2010 Glad you installed tons of these.... I know the shop that installed them, ended up extending the tranny mount bracket another 1" to make the DP sit right on the turbo. Just wondering others had similar issues or maybe its just my particular DP, or install. Ill try to get some pics up. Thanks Link to comment Share on other sites More sharing options...
m sprank Posted December 22, 2010 Share Posted December 22, 2010 Huh? Are you sure you have the right downpipe? What turbo are you using? Something is wrong. Link to comment Share on other sites More sharing options...
TRSCobra Posted December 23, 2010 Share Posted December 23, 2010 Sounds like maybe he has the pipe for manual cars. Link to comment Share on other sites More sharing options...
MadMontie1 Posted December 23, 2010 Share Posted December 23, 2010 mine's slightly lower than stock, but by no means doe it hit. i second that something is not installed right Link to comment Share on other sites More sharing options...
m sprank Posted December 23, 2010 Share Posted December 23, 2010 Waiting for pix. OP has PM'd me. He might have the right pipe. Not sure yet. Link to comment Share on other sites More sharing options...
mustangendsley Posted December 23, 2010 Share Posted December 23, 2010 slow down and don't have your car so low to the ground. raise your ride a little bit. Link to comment Share on other sites More sharing options...
m sprank Posted December 23, 2010 Share Posted December 23, 2010 After discussing the method(s) used to install the pipe. I doubt the car is too low. I have a bad feeling he got worked over by some shady install. Someone took a torch to the DP to make it "fit". Claimed it was normal to do it to all downpipes. Invidia too. Claimed downpipe did not mate to turbo or CBE, so pipe needed to be modded. Claimed they do it "all the time". WTF?! I explained the old divider plate issue with Onvidia pipes. Plus the Perrins being close to the firewall. But no one is using torches to install DP's. CNT/ERZ even has a fit guarantee. If for some reason the pipe does not fit it is replaced for free. All pipes come from the same fixture. The manufacturers know the pipes fit. Link to comment Share on other sites More sharing options...
Deadleave Posted December 25, 2010 Author Share Posted December 25, 2010 Best I could do with phone cam in a dark room Link to comment Share on other sites More sharing options...
m sprank Posted December 25, 2010 Share Posted December 25, 2010 I do not know why they did that. It looks like an AT pipe. Does it have a bend about 4 inches from the CBE flange? It should be set on the "J" hook and then torqued at the Turbo, torqued at the CBE and then at the "J". Got any pix of what is going on at the turbo and CBE? Link to comment Share on other sites More sharing options...
Deadleave Posted December 25, 2010 Author Share Posted December 25, 2010 I'll try to better pics, at least I know I'm not crazy. And I don't think cars sits that low. Link to comment Share on other sites More sharing options...
m sprank Posted December 25, 2010 Share Posted December 25, 2010 I see the extension on the hook fine. Its hard to see how low the pipe hangs. But I have a car in the driveway with the same pipe, so I can compare in the morning when it is light out. Pix of the CBE connection and at the turbo would be nice. Also, to know if the pipe has that slight bend just before the CBE. Link to comment Share on other sites More sharing options...
dr_sharp Posted December 26, 2010 Share Posted December 26, 2010 Yuck. You should post up the name of the shop so others can avoid. lol Link to comment Share on other sites More sharing options...
Spec B Posted April 22, 2011 Share Posted April 22, 2011 Did this ever get corrected...friend of mine is having the same exact ground clearance issue. Link to comment Share on other sites More sharing options...
05_LGT Posted April 22, 2011 Share Posted April 22, 2011 This is so annoying. Here is a shot of my CNT DP. I will be posting a new thread soon. Link to comment Share on other sites More sharing options...
Deadleave Posted April 22, 2011 Author Share Posted April 22, 2011 No, mine was never corrected, and that due to the DP itself. I had the shop check it out. Bend is just bad/ fit issue. It does come down that low, if both the exhaust side and turbo side is mounted flush. When they tried a unmodified bracket, it caused a gap to form on both the turbo and exhaust side. At least now I know its not just me. Link to comment Share on other sites More sharing options...
Spec B Posted April 22, 2011 Share Posted April 22, 2011 I assume these are a couple of isolated cases...guess you could pull it off and get a new, properly fitting pice. Sucks.. Link to comment Share on other sites More sharing options...
05_LGT Posted April 22, 2011 Share Posted April 22, 2011 I contacted ERZ and they said they sent the correct DP. They asked for some additional shots + they have NEVER had an issue like this. I'm about two seconds from blowing my top Link to comment Share on other sites More sharing options...
Deadleave Posted April 22, 2011 Author Share Posted April 22, 2011 Point them to this thread, at least 3 ppl with the same issue Link to comment Share on other sites More sharing options...
Spec B Posted April 22, 2011 Share Posted April 22, 2011 Is there anything else that could cause such poor fitment? Link to comment Share on other sites More sharing options...
goneskiian Posted April 22, 2011 Share Posted April 22, 2011 Are these all AT's that are having issues? Link to comment Share on other sites More sharing options...
SC GT Posted April 22, 2011 Share Posted April 22, 2011 I had an ERZ catted for a manual that didn't fit right. Had to pretty much hang on it to get it to line up with the CBE. Wound up getting a refund from the vendor with very little trouble, and didn't read of any similar complaints from anyone with the same DP, so didn't post my problem. This was almost a year ago. Link to comment Share on other sites More sharing options...
05_LGT Posted April 22, 2011 Share Posted April 22, 2011 Are these all AT's that are having issues? 5EAT on mine and deadleave i believe Link to comment Share on other sites More sharing options...
jhawk222 Posted April 25, 2011 Share Posted April 25, 2011 [ATTACH]93888[/ATTACH] [ATTACH]93889[/ATTACH] [ATTACH]93890[/ATTACH] [ATTACH]93891[/ATTACH] Best I could do with phone cam in a dark room Could that be a certain shop on Fulton St.??? Hmmmmm Link to comment Share on other sites More sharing options...
