CGuava Posted April 1, 2011 Share Posted April 1, 2011 This may need to be in transmissions, but I figured I'd ask here first. I've been trying to find a good write-up on a clutch job, and all I can find is the youtube videos. The are put together nicely and very informative. Unfortunately a bit unclear about the bell housing bolts. I'm fairly certain I got them all, but I can't get the tranny separated from the motor (with ease). Before I go crazy with screwdrivers and prybars, I just want to make sure I've got them all. I've gotten the two starter bolts, two studs with nuts on the bottom. 2 bolts near the bottom studs, and both the top bolt (rightish side) and bolt that is slightly behind the turbo. So I've got 6 bolts and 2 nuts. Anything else in the connection that needs to be disco'd? I'd consider myself mechanically inclined, I've done numerous clutch/engine jobs, and typically the tranny just pulls off when the bolts are off. This is the newest vintage of vehicle I've ever done a clutch on. Just want a double check to make sure I'm not missing anything before I start using force. FWIW, it's a 2006. Got the clutch parts and I'm ready to re-install want to put back in, just need to get them in there. Any input from the experienced? What method did you guys use to separate the tranny from motor if you needed it? Link to comment Share on other sites More sharing options...
car_cursed Posted April 1, 2011 Share Posted April 1, 2011 did you get the top allen bolt? Link to comment Share on other sites More sharing options...
car_cursed Posted April 1, 2011 Share Posted April 1, 2011 http://www.scoobymods.com/diy-lethals-02-05-wrx-t12071.html?t=12071&highlight=clutch just use this for the pics, all his special tools and such are completely un necessary. Link to comment Share on other sites More sharing options...
car_cursed Posted April 1, 2011 Share Posted April 1, 2011 it will seperate easily once you get that 10mm allen plug out, and removed the pitch fork pin. I've done two clutches and one sti trans swap on a wrx. i imagine the legacy is the same. Link to comment Share on other sites More sharing options...
CGuava Posted April 1, 2011 Author Share Posted April 1, 2011 Don't have that allen bolt. Was able to get it slightly separated today though. Link to comment Share on other sites More sharing options...
