BeauTofAWD Posted January 4, 2013 Share Posted January 4, 2013 A couple weeks ago, I thought I started seeing my headlights dim while I was driving just for a moment and then return normal. It was happening so quickly and sporadically, I thought I was going crazy. This morning on my way to work, I noticed that that it is happening for sure. I have an '05 LGT Wagon, 126k miles. I have Silverstar bulbs. No aftermarket stereo, amps, subs, etc. I'm thinking, maybe the alternator but not sure. Any thoughts? Link to comment Share on other sites More sharing options...
GTPpilot Posted January 4, 2013 Share Posted January 4, 2013 Could it be happening briefly when the A/C compressor kicks in ? I notice this happening on my '08. Very quick. Link to comment Share on other sites More sharing options...
BeauTofAWD Posted January 4, 2013 Author Share Posted January 4, 2013 That also crossed my mind too. Nothing else seems to be going on other than that. I guess I may be paranoid? LOL Link to comment Share on other sites More sharing options...
AkumaMax Posted January 4, 2013 Share Posted January 4, 2013 well if it is noticeable to you my guess is either the battery or Alternator. Could also be that the Alternator belt needs adjusting. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted January 4, 2013 Share Posted January 4, 2013 Just go to autozone. They'll test your battery and alternator for free. Link to comment Share on other sites More sharing options...
funnyman06 Posted January 5, 2013 Share Posted January 5, 2013 I swear mine do the same sometimes Link to comment Share on other sites More sharing options...
robinlsb Posted January 5, 2013 Share Posted January 5, 2013 Ditto. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Umass94 Posted January 5, 2013 Share Posted January 5, 2013 Same here. Here's proof: Just 1 minute after buying my OBXT, I had 7 phone calls from insanely hot women, and got 7 dates out of it. Coincidence? I think not. Link to comment Share on other sites More sharing options...
max Posted January 6, 2013 Share Posted January 6, 2013 happened to me as well, on other then subaru cars. it was poor grounding. i cleaned all ground points (sprayed with terminal cleaner, dry and put some dielectric compound to block air and moisture). never had problems again. yet to see it on my subie. Link to comment Share on other sites More sharing options...
-Samurai- Posted January 6, 2013 Share Posted January 6, 2013 Had a '97 Celica that did this but I never had problems with it. So I just left it be. It would do it sometimes when braking. Could of been my battery, it was getting close to replacement time. Link to comment Share on other sites More sharing options...
branab3 Posted January 6, 2013 Share Posted January 6, 2013 same here. Does everybody it is happening to have a seat heater? It only seems to happen to me when the seat heater is on. Mine has a newer belt and battery too, but happened before those........ Link to comment Share on other sites More sharing options...
snowflake Posted January 6, 2013 Share Posted January 6, 2013 Happened to me in my old 06 sti..i thought i was going nuts when it first happened. I never fixed it but a few months after first noticing the dimming, the idler pulley on the ac side went out...maybe it was going out and causing a strain of power? Meh sold the car, and havent had an issue with my legacy...yet Sent from my DROID BIONIC using Tapatalk 2 Link to comment Share on other sites More sharing options...
05sleeper Posted January 7, 2013 Share Posted January 7, 2013 Happens on my legacy every now and then when I put the clutch in. I need to test the alternator and check my grounds Link to comment Share on other sites More sharing options...
