DHracer Posted July 14, 2011 Share Posted July 14, 2011 I have a creak that is driving me nuts, after 3 weeks I can't seem to find the exact problem. Its in the front end somewhere but just cant pin point it. Everything seems to be fine and tight from what I can see. I hear the creak if I push the car foward and backward as far as I can when its parked or when accelerating from a stop or coming to a stop. It used to be only at slow speeds but now its all the time. Anybody have a similar problem or any thoughts what it may bee Link to comment Share on other sites More sharing options...
robinlsb Posted July 14, 2011 Share Posted July 14, 2011 WD40 the sway bar bushings. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
PoisonousBeef Posted July 16, 2011 Share Posted July 16, 2011 Have to disagree with the WD-40, which is largely a solvent similar to kerosene and IMO doesn't belong anywhere near rubber bushings. WD-40 says it's safe for rubber and I'm sure people use it so I'm not saying it's a fact that it's wrong, I just disagree with the recommendation. Teflon lube designed for urethane suspension bushings is a better solution if you can find it. Otherwise, a water-based lube known as "RuGlyde" is available from NAPA. Link to comment Share on other sites More sharing options...
peteyjr Posted July 17, 2011 Share Posted July 17, 2011 Is the RUglyde dual purpose ? Car and bedroom lube too? Link to comment Share on other sites More sharing options...
lordhowe Posted July 18, 2011 Share Posted July 18, 2011 I have a creak that is driving me nuts, after 3 weeks I can't seem to find the exact problem. Its in the front end somewhere but just cant pin point it. Everything seems to be fine and tight from what I can see. I hear the creak if I push the car foward and backward as far as I can when its parked or when accelerating from a stop or coming to a stop. It used to be only at slow speeds but now its all the time. Anybody have a similar problem or any thoughts what it may bee does it make that sound when going over a speed up with different wheels. for example: when you approach a speed bump on an angle, you have one wheel one before the other one gets on the speed bump. I had a similar problem and I had to tighten my sway bar where the end links are. Link to comment Share on other sites More sharing options...
DHracer Posted July 18, 2011 Author Share Posted July 18, 2011 Its def not the sway bar bushings, greased them and no difference. Seems like its getting worse too, almost like a clunk, sometimes a creak. I thing I had the location wrong at first, almost sounds like its in/under the back seat but kinda hard to tell. speed bumps and bumps in the road have no effect, no creaks. only accelerating/decelerating I hear this creak/clunk. Link to comment Share on other sites More sharing options...
SilentOne Posted July 19, 2011 Share Posted July 19, 2011 I had the same sound creak/clunk- only happened every once in awhile as my 06' LGT is sittin at 45k. I had the front and rear differential fluid changed and haven't heard the creak/clunk since. That might be a mad stab in the dark- FYI! Link to comment Share on other sites More sharing options...
grecod Posted July 20, 2011 Share Posted July 20, 2011 My 05 made a creak sound the turned into a clunk, it was more noticeable with the windows down when I'd hit a bump. Turned out it was the front end links and it's a very common issue with these cars. Only set me back a couple hundred in parts. If you go aftermarket watch what you order and ask for advice on here, I went OEM. Link to comment Share on other sites More sharing options...
