latitudes Posted November 13, 2007 Share Posted November 13, 2007 I have a 1995 subaru legacy wagon, automatic tranny. When I push the button on the shifter to shift out of park, the button won't fully depress and I hear a clicking behind the stearing wheel, somewhere in the dashboard. Durring this process, I have my foot on the brake peddle. The shifter has been touchy since I bought the car a year ago - I always had to rock or wiggle the shifter to get the button to depress. now it appears that whatever was wearing out has finally broken. Is there a way to disable the shift interlock, at least temporarily so I can get the beast out of park and to a mechanic? Thanks! -Hannah Link to comment Share on other sites More sharing options...
whitetiger Posted November 13, 2007 Share Posted November 13, 2007 Id try to get a wireing diagra, of the shift interlock circuit. you may have a loose connection somewhere. Or the solenoid on the shifter could have gone bad. its located on the shifter assembly if im not mistaken. you will have to remove the center console and get a look at it. Generally, these are engaged in a powereed off position so in order to get it out of park, you will have to remove the solenoid, or disconnect the shifter cable from the shifter and pull it by hand in to D. ive done this several times on other cars, but you still have to remover the center console. Link to comment Share on other sites More sharing options...
latitudes Posted November 13, 2007 Author Share Posted November 13, 2007 Any idea where to get a wiring diagram online? I live in the US Virgin Islands and nothing is ever in stock, manual-wise... Link to comment Share on other sites More sharing options...
whitetiger Posted November 13, 2007 Share Posted November 13, 2007 No, sorry. Will have to go to a dealership to look at the manual. Maybe they will let you make a photocopy of the pages you need. Link to comment Share on other sites More sharing options...
SLegacy99 Posted November 13, 2007 Share Posted November 13, 2007 There is a shiftlock override. I believe you have to pop the console off and stick a screw driver in something. The manual has instructions I know that. Link to comment Share on other sites More sharing options...
Bdubs Posted November 13, 2007 Share Posted November 13, 2007 Okay, looking at my FSM it appears the Shift Lock Control Module is under the steering wheel column on your left (LHD version). Remove the panel under the steering wheel if you are unable to get to it. I believe if you just unplug it the unit, it shouldn't give you anymore problems. Link to comment Share on other sites More sharing options...
GBY Posted November 13, 2007 Share Posted November 13, 2007 moved to transmissions forum Link to comment Share on other sites More sharing options...
pillboy Posted November 13, 2007 Share Posted November 13, 2007 There is a shiftlock override. I believe you have to pop the console off and stick a screw driver in something. The manual has instructions I know that. There is probably a little access hole by the shifter, covered with a little plastic cover (about 1/2" X 3/4" or a little smaller) you need to pry out with a small screwdriver. The owner's manual covers this. It allows you to drive the car for service when the interlock fails. It is still ugly. Link to comment Share on other sites More sharing options...
SLegacy99 Posted November 13, 2007 Share Posted November 13, 2007 There is probably a little access hole by the shifter, covered with a little plastic cover (about 1/2" X 3/4" or a little smaller) you need to pry out with a small screwdriver. The owner's manual covers this. It allows you to drive the car for service when the interlock fails. Not in the 4EAT that I had. Link to comment Share on other sites More sharing options...
pillboy Posted November 14, 2007 Share Posted November 14, 2007 Not in the 4EAT that I had. Out '02 4EAT has it and I will bet Seb's life on it that our '97 4EAT had it too. Every Jap car I ever remember being in has had it that I can remember. Oh well, I'm old and almost senile. It is still ugly. Link to comment Share on other sites More sharing options...
SLegacy99 Posted November 14, 2007 Share Posted November 14, 2007 I had a '96, I guess they could have changed it for '97 but since this is a '95 in question I would just consul the manual. Link to comment Share on other sites More sharing options...
mzsinko84 Posted January 20, 2020 Share Posted January 20, 2020 I have an 05 LGT Limited with a 5EAT transmission and it has this on the the upper left corner. Link to comment Share on other sites More sharing options...
mzsinko84 Posted January 20, 2020 Share Posted January 20, 2020 I have an 05 LGT Limited with a 5EAT transmission and it has this on the the upper left corner of the shifter colum or the shifter bezel. Link to comment Share on other sites More sharing options...
Rick2019 Posted January 21, 2020 Share Posted January 21, 2020 Unplug and join the wires together Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
