magnoon Posted November 7, 2011 Share Posted November 7, 2011 So lately my CD player has been a bit moody. Sometimes it will turn on and work, other times it will turn on, make a few mechanical noises and turn off, and sometimes ill be mashing the cd button and it just wont do anything. When it doe work, it'll turn off if i try to switch cds. also, before it turns off all the screens and lights int he center consol flash 2 or 3 times... any thoughts?? Radio works fine.... Thanks! -Chris Link to comment Share on other sites More sharing options...
2.5GT_dude Posted November 7, 2011 Share Posted November 7, 2011 have you checked the fuses? Link to comment Share on other sites More sharing options...
Alfred_Buchi Posted November 7, 2011 Share Posted November 7, 2011 Loose connection somewhere. Did you use a plug and play harness or did you splice wires? I've seen tons of weird CD player issues that were the result of a bad install. I'd pull the unit and check that your fuses are in tight (if they were blown you wouldn't have intermittent issues, you'd have nothing) and that all your wires are connected well. Link to comment Share on other sites More sharing options...
magnoon Posted November 8, 2011 Author Share Posted November 8, 2011 it's not an aftermarket system, its the stock system, so no wire anything has been done. Ill check the fusebox and see whats up. its been giving me nothing for about a week now, so maybe that could be the culprit Link to comment Share on other sites More sharing options...
2.5GT_dude Posted November 8, 2011 Share Posted November 8, 2011 if you pull the stereo out and smell anything burnt that's usually a definite sign of bad Link to comment Share on other sites More sharing options...
KCwagon Posted November 8, 2011 Share Posted November 8, 2011 I had the same issue with mine. The CD player finally stopped working, then the radio would not change stations....then the climate control became stuck on A/C/auto...then I replaced the unit with another factory unit and everything is good again. Link to comment Share on other sites More sharing options...
