BlueLeg Posted August 28, 2006 Share Posted August 28, 2006 So I go out for dinner the other night and come home, park the car. I go to bed and wake up to see my running lights on. The headlights are switched to the off position and regardless of wether they're turned on or not when I turn the ignition off the lights should all turn off. I tried disconnecting the battery to see if maybe the computer would reset and fix the problem but the lights are still on. So i've been having to take the fuse out at night so my battery doesn't die. Mods are as follows and i know they wouldn't have an effect on this problem: AVO Boost actuator, K&N intake, GFB blow off valve. Any ideas before I take it to the shop? Link to comment Share on other sites More sharing options...
underpowerd Posted August 28, 2006 Share Posted August 28, 2006 we all do it once. there's a (useless) switch on top of the steering column you must have hit on. (and always run a search b4 u go to the shop ) Link to comment Share on other sites More sharing options...
rallispec Posted August 28, 2006 Share Posted August 28, 2006 whats funny is that I took my car to the shop one time (for an unrelated reason) - and they actually called me to tell me that they couldnt turn off of the lights and wanted to know what to do. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 28, 2006 Share Posted August 28, 2006 we all do it once Link to comment Share on other sites More sharing options...
JBLU24 Posted August 28, 2006 Share Posted August 28, 2006 its the blow off valve                  kiddinggggggggggggggg Link to comment Share on other sites More sharing options...
whitetiger Posted August 28, 2006 Share Posted August 28, 2006 the infamus battery drain switch strikes again Link to comment Share on other sites More sharing options...
BlueLeg Posted August 29, 2006 Author Share Posted August 29, 2006 I don't know wether to feel stupid or wether to be pissed off at subaru for putting such a retarded "feature" on our cars. Or pissed off at the dealer for not warning me about this bullshit. haha anyways thanks a lot guys. Link to comment Share on other sites More sharing options...
pillboy Posted August 29, 2006 Share Posted August 29, 2006 It is still ugly. Link to comment Share on other sites More sharing options...
sexylegacy Posted August 29, 2006 Share Posted August 29, 2006 Anyone actually know what Subaru's REAL purpose is for the "battery drain switch"? Link to comment Share on other sites More sharing options...
automaticsti Posted August 29, 2006 Share Posted August 29, 2006 "battery drain switch"........................DUH Link to comment Share on other sites More sharing options...
MilesA Posted August 29, 2006 Share Posted August 29, 2006 Anyone actually know what Subaru's REAL purpose is for the "battery drain switch"?Yes, it's there so you can keep your parking lights on if you need to take the ignition key out. By default, our cars are set up so that all lights go off when you turn off the key. You need some way to override the default. Let's say you have to leave the car parked by the side of the road for a few minutes, and you'd like to make sure other drivers don't run into it. Turn on your parking light switch and take your key with you -- that's why they're called parking lights! I don't understand why some people think it's a useless feature. Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted August 29, 2006 Share Posted August 29, 2006 ^^ hazards do the job just fine Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 29, 2006 Share Posted August 29, 2006 ^^ hazards do the job just fine Link to comment Share on other sites More sharing options...
rallispec Posted August 29, 2006 Share Posted August 29, 2006 most cars have it built into the headlight switc - you can choose between full off / ambers only / headlights and ambers / high beams... For watever reason, subaru pulled the amber only option off the headlight switch and stuck it on the stearing column.   The only time I've ever really seen other people use ambers only is in parking garages - when you don't want to blind people with headlights - but want to be visible in the reduced light.. (maybe thats where the name parking lights comes from?) Link to comment Share on other sites More sharing options...
MilesA Posted August 29, 2006 Share Posted August 29, 2006 ^^ hazards do the job just fineThat depends on where you live. In many parts of the world, the parking lights are required by law and/or customary. May be an outdated custom that you don't personally care about, but that is why they are there. Link to comment Share on other sites More sharing options...
pillboy Posted August 29, 2006 Share Posted August 29, 2006 For watever reason, subaru pulled the amber only option off the headlight switch and stuck it on the stearing column. Â It IS on the signal stalk, but only works when the ignition switch is in the "run" position. It is still ugly. Link to comment Share on other sites More sharing options...
Fallschirmjaeger Posted August 30, 2006 Share Posted August 30, 2006 It's only a 'useless feature' to American drivers...kinda like rear fog lights are. In other parts of the world they save you from getting side-swiped on unlit, narrow roads that date back to the Dark Ages. Link to comment Share on other sites More sharing options...
j255c Posted August 31, 2006 Share Posted August 31, 2006 +1 for hazards -1 for parking light switch (got me 2 weeks after i owned the car) 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
KMP Posted April 26, 2009 Share Posted April 26, 2009 Thanks guys Link to comment Share on other sites More sharing options...
Guest JessterCPA Posted April 26, 2009 Share Posted April 26, 2009 Holy thread resurrection Batman! Link to comment Share on other sites More sharing options...
PhilT Posted April 26, 2009 Share Posted April 26, 2009 Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
KMP Posted April 26, 2009 Share Posted April 26, 2009 saved me a trip to the dealership - yay! Link to comment Share on other sites More sharing options...
jivingt Posted January 14, 2010 Share Posted January 14, 2010 Thanks guys Link to comment Share on other sites More sharing options...
jwbronco Posted February 21, 2010 Share Posted February 21, 2010 I'll admit it just got me, cut the wires that come from the stock sub to run my own amp and couldn't figure out wtf happened and never saw a connection but against my own judgement I undid everything. God that pissed me off...stupid design but i know it's needed but they could design the switch somewhere else maybe.....a switch that glows so you know it's on. Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted February 21, 2010 Share Posted February 21, 2010 That would be smarter, but not as much fun for the rest of us Link to comment Share on other sites More sharing options...
