KevinA Posted January 13, 2014 Share Posted January 13, 2014 I have a 2005 LGT, and my gear shifter is very sloppy. I replaced the bushing on the shifter itself with the cobb poly and it hasn't made any difference. I tried to explain it in a video here: https://www.dropbox.com/s/9bd8jv7e8jzf50i/2014-01-13%2018.01.38.mp4 Where should i start looking next, or is this normal? Link to comment Share on other sites More sharing options...
JermTheElf Posted January 13, 2014 Share Posted January 13, 2014 Make sure the snap ring on the base of the shifter is in and tight. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 13, 2014 Share Posted January 13, 2014 Tighten the bolts that hold the shifter on the tranny. Get under the car and tighten any bolt there you can. 12mm box wrench if I remember right. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
