Fake Outback Posted June 10, 2013 Share Posted June 10, 2013 Alright, this is sort of a noob question but I haven't had to put my car up on jack stands for a while and also would like to know the right way of doing it. I am pretty sure that I used to do it on the subframe rails (further into the centre of the car from the stock jack pinch rails), but is this correct? Where are the proper jacking points and where should I place my jack stands? Have to keep in mind that my jack stands don't have a deep enough indentation on top to prevent the pinch rails from getting crushed if I were to place the jack stands in the stock jack locations. Link to comment Share on other sites More sharing options...
spooln30 Posted June 10, 2013 Share Posted June 10, 2013 On our cars in the front I jack up using that black part bolted onto the subframe in the center, that's why it's there, and place the stands on the frame rails. They sometimes will dent in but it's better then the pinch weld or rockers. I also never jack up using the pinch welds. I've seen too many older cars bend up in these points. For the rear I use the diff and stands on the front lateral mounting brackets. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted June 10, 2013 Share Posted June 10, 2013 I jack them up on the pinch welds because they've all been bent to hell from other people's endeavors anyway :\ Link to comment Share on other sites More sharing options...
Zues Marine Posted June 10, 2013 Share Posted June 10, 2013 ^ same here Link to comment Share on other sites More sharing options...
Drew888 Posted June 10, 2013 Share Posted June 10, 2013 There was a Huge thread on this just a short while ago. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
famaya26 Posted June 10, 2013 Share Posted June 10, 2013 Where? Link to comment Share on other sites More sharing options...
Zues Marine Posted June 10, 2013 Share Posted June 10, 2013 There was a Huge thread on this just a short while ago. certainly not in the second gen forums Link to comment Share on other sites More sharing options...
Fake Outback Posted June 11, 2013 Author Share Posted June 11, 2013 heh yeah, i did a bunch of searches in here before making a new thread and found no conclusive results and def no huge threads.. i suppose i will stick to the subframe/frame rails i was using before. Link to comment Share on other sites More sharing options...
