brucelee Posted June 25, 2009 Share Posted June 25, 2009 After doing a lot of research on this subject, even on this forum, I haven't found the simple answer that I was seeking, which I ended up finding on my own.. I swapped my seats for Sparco EVO 2's, which obviously didn't have the proper seatbelt electronic plug that our stock seats have... After I changed the seats I found out how annoying that damn seatbelt chime can really be... Even though I had my seatbelt plugged in properly, there was no electronic signal telling the car that the belt is properly fastened... Instead of cutting into the wires, or doing the 20 key turn trick every time, I took a piece of metal wire and mated it with the open end of the car's seatbelt electronic cable (The one that you unplugged to remove the seat). All you do is literally stuff that piece of metal into the open plug, and tape it shut, and that's it... The seatbelt cable becomes terminated and thinks the seatbelt is plugged in at all times, no more seatbelt chime!!! Just thought I'd share that with you guys since I didn't find any forum with that info before, and I wish it was there when I was looking up info! No you know, and knowing is half the battle. Link to comment Share on other sites More sharing options...
Darkness of Death Posted June 25, 2009 Share Posted June 25, 2009 G i joe ~ Link to comment Share on other sites More sharing options...
SubieBlkOut Posted June 26, 2009 Share Posted June 26, 2009 So this would work on both front seats correct. I get so tired of telling my pass to buckle up when we are just sitting in the car with the key on! Any pics? Really all you did was jumper it to complete the circuit right? Link to comment Share on other sites More sharing options...
Gire Posted June 26, 2009 Share Posted June 26, 2009 5 years in and none of us thought about a wire jumper trick? I'll try this out tomorrow. I am tired of the 20 key trick re-setting on me every time I re-set the ECM. Nice work OP! Link to comment Share on other sites More sharing options...
krud Posted June 27, 2009 Share Posted June 27, 2009 A bit off topic but, got any pics of your seats installed? Link to comment Share on other sites More sharing options...
brucelee Posted June 27, 2009 Author Share Posted June 27, 2009 So this would work on both front seats correct. I get so tired of telling my pass to buckle up when we are just sitting in the car with the key on! Any pics? Really all you did was jumper it to complete the circuit right? Yeah, it's that simple. I can't believe I was the only one that thought of the simple way... All these complicated ways, when all that needed to happen was terminating it. You might have to reset your ECU, keep that in mind. PS: Sorry, no pics right now, as soon as I get them I'll post them up. Link to comment Share on other sites More sharing options...
brucelee Posted July 10, 2009 Author Share Posted July 10, 2009 Anyone try it? Link to comment Share on other sites More sharing options...
