DansSpace Posted September 20, 2010 Share Posted September 20, 2010 Alright guys, so I'm going to be replacing my clutch here, and I found this one, and it says it comes with "Bearing and alignment took kit". Is this "bearing" the throwout bearing that is oh-so recommended to be replaced whilst doing the clutch? And I've read that the Spec stage 1 clutch is compatible with the stock LGT flywheel, am I correct? Thank you guys! http://www.importimageracing.com/p/Spec-Stage-1-Clutch-05-07-Legacy-GT.html Link to comment Share on other sites More sharing options...
robbie_R Posted September 21, 2010 Share Posted September 21, 2010 The clutch could be if it's intended for a LGT. Most clutch kits include a release bearing though. I would recommend against Spec as they start to chatter shortly after the break-in process. Link to comment Share on other sites More sharing options...
Heedz Posted September 21, 2010 Share Posted September 21, 2010 our clutches for 05-06 i think are dual mass soooo you need a wrx flywheel cause i looked at it and it said it fits wrx 06+ too.. Link to comment Share on other sites More sharing options...
DansSpace Posted September 21, 2010 Author Share Posted September 21, 2010 Urghhh. Any clutch suggestions that would work with the stock flywheel? Link to comment Share on other sites More sharing options...
timmahh Posted September 21, 2010 Share Posted September 21, 2010 There are spec and act clutches that work with the factory DMFW My clutch is getting replaced tomorrow w/ a spec stage 2 i bought from a member here. The WRX thing works if you have to replace the clutch and flywheel, the WRX or 07-09 Legacy GT flywheels are single mass and mucho cheaper than the $500 factory DMFW. You can probably get your stock DMFW resurfaced if it isn't beat to crap Oh and no matter what clutch kit you get, you need to get the TSK-3 kit to prevent premature failure of the crappy factory throwout bearing setup! Link to comment Share on other sites More sharing options...
