Derrickmd30 Posted March 21, 2014 Share Posted March 21, 2014 Anyone install a tablet or cell phone in there legacy? If so you have any pictures? Sent from my SM-N900T using Tapatalk Link to comment Share on other sites More sharing options...
blankdeluxe Posted March 21, 2014 Share Posted March 21, 2014 Link to comment Share on other sites More sharing options...
Derrickmd30 Posted March 21, 2014 Author Share Posted March 21, 2014 How hard was it to put in? Sent from my SM-N900T using Tapatalk Link to comment Share on other sites More sharing options...
blankdeluxe Posted March 21, 2014 Share Posted March 21, 2014 Its a pain if you want to have it removable and you have to cut up the bezel a hard wire in some power to keep it on. You also have to root the tablet to a specific rom that will basically put the tablet in a "sleep" mode when the car is turned off and turn the screen back on when you start it up. You also have to address not being able to reach the power button anymore if you need it for anything. All in all I decided it wasn't really worth all the work to keep it in the car so I ended up replacing it with just a standard double din touch screen radio. I have a fair amount of documentation on it if you do decide to try it out anyway so just let me know if you need a hand. EDIT: I forgot about all the special cables I had to find too for OTG and power at a 90* to clear the inside of the bezel. And you have to figure out an antenna if you want to pick up AM/FM and some sort of an amp to power your speakers. Link to comment Share on other sites More sharing options...
Derrickmd30 Posted March 21, 2014 Author Share Posted March 21, 2014 Yeah I'm debating on doing a indash install or doing a out of dash removable bracket install. I have clear wireless Internet which works off a isb power and battery last 6 hours and it's usb rechargeable for it. Or might root my note 3 and use that internet. I wanted to make a XBMC setup in the car that can do, Pandora, navigation, torque OBD2. I was thinking about just using my note 3 but haven't made a decision. Sent from my SM-N900T using Tapatalk Link to comment Share on other sites More sharing options...
TbirdMan Posted March 21, 2014 Share Posted March 21, 2014 something to note that might help with this, the first gen Nexus 7 has "pogo" pins on the side that are used for the docking station, two output stereo audio, and the other two are for charging, you can learn more about that on the XDA forums. IIRC someone was working for a ROM that was designed for car use. Link to comment Share on other sites More sharing options...
Derrickmd30 Posted March 21, 2014 Author Share Posted March 21, 2014 Ok. I'm actually on xda. Started with the galaxy 1 Sent from my SM-N900T using Tapatalk Link to comment Share on other sites More sharing options...
blankdeluxe Posted March 21, 2014 Share Posted March 21, 2014 I used a N7. And there is a Rom out for car use. Its Cm10 based i think. Here is the link. Link to comment Share on other sites More sharing options...
boattlebot Posted March 22, 2014 Share Posted March 22, 2014 my friend had an ipad in his dash for all of a week and he took it out. my advice? get yourself a good radio and do everything you want through the head unit through aux or usb. Link to comment Share on other sites More sharing options...
blankdeluxe Posted March 22, 2014 Share Posted March 22, 2014 my friend had an ipad in his dash for all of a week and he took it out. my advice? get yourself a good radio and do everything you want through the head unit through aux or usb. Smart advice. Mine lasted about a week as well Sent from my LG-D800 Link to comment Share on other sites More sharing options...
vr4 Posted March 22, 2014 Share Posted March 22, 2014 Ummmm... http://m.ebay.com/itm?itemId=121230879434 http://forum.xda-developers.com/showthread.php?t=2528349 Link to comment Share on other sites More sharing options...
blankdeluxe Posted March 22, 2014 Share Posted March 22, 2014 Ummmm... http://m.ebay.com/itm?itemId=121230879434 http://forum.xda-developers.com/showthread.php?t=2528349 There is one if you shop around where the tablet actually is removable from the double din but its gingerbread so its pretty worthless Sent from my LG-D800 Link to comment Share on other sites More sharing options...
jakeafton Posted March 22, 2014 Share Posted March 22, 2014 I have a standard mount and an optimus g phone I use. Bluetooth connection to my obdii port. The torque app puts all ecu info right there, I created a custom dashboard with avg mpg, instant mpg, air/fuel, o2v., coolant temp., vacuum, etc. I thought about doing all that in dash, but like it was mentioned, power and everything else, meh...this is simple to remove and looks clean. Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Zues Marine Posted March 22, 2014 Share Posted March 22, 2014 Awesome... I remember this thread and was trying to find it again... Considering going this route instead of a new headunit Link to comment Share on other sites More sharing options...
