McCarthy69 Posted December 10, 2008 Share Posted December 10, 2008 whats up. I was wondering if anyone knew what subaru dealerships use as a scan tool. for example at saab we use a tech 2 specifically for saab and pretty much monitor everything on the car with it as well as change settings. so if you know or have an idea what it is or where to look to find out let me know. thanks Link to comment Share on other sites More sharing options...
PeterJMC Posted December 10, 2008 Share Posted December 10, 2008 Subaru dealerships use a tool called Subaru Select Monitor III (http://techinfo.subaru.com/html/specialToolInfo.jsp) You can also use the Hitachi Diagnostic System (http://www.bsecorp.com/hds.php) Link to comment Share on other sites More sharing options...
Jon in CT Posted December 10, 2008 Share Posted December 10, 2008 for example at saab we use a tech 2 specifically for saab and pretty much monitor everything on the car with it as well as change settings.Does the Tech2 tool work on the Saab 9-2X? Link to comment Share on other sites More sharing options...
McCarthy69 Posted December 11, 2008 Author Share Posted December 11, 2008 ;2201395']Does the Tech2 tool work on the Saab 9-2X? actually we just had this problem today. The tech 2 does not work on the 9-2. but we used this thing called the vdm-vdi. the vdm is the vehicle diagnostic monitor which is a program installed on a laptop. the vdi is the vehicle diagnostic interface which is a small computer looking thing that connects to the obd2 port and connects to the laptop thru usb. we had to borrow if from a dealership in new london. from above- http://www.bsecorp.com/hds.php this is the exact vdi we used. Thanks for the info about the suabru scan tool peterjmc Link to comment Share on other sites More sharing options...
