Pedestrian Posted January 11, 2008 Share Posted January 11, 2008 I recently purchased an RBS front lip with a 6" lateral crack in it (got it dirt cheap, couldn't resist). I'm new to the New England area, and don't know of any reputable shops locally that I could take it to, so I was thinking about tackling the fix myself. From what I have read, a good (non-premixed) bondo should do the trick, but my lack of experience makes me weary of an attempt. Does anyone have any advice/suggestions for approaching this, or know of any shops around Amherst that could fix it for relatively cheap? Also, would anyone be interested possibly helping me? I would be more than happy to travel to you, and provide beer of course Link to comment Share on other sites More sharing options...
RobE Posted January 11, 2008 Share Posted January 11, 2008 im no expert, nor have i done this myself, but i think using fiberglass would be your best bet. ive done plenty of work with fiberglass before and its pretty easy to use and its quite strong. id be willing to help you out......but you are pretty far away. http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
Spec B Posted January 11, 2008 Share Posted January 11, 2008 If it is just a crack you may be able to do it with bondo and sandpaper.. I did my grill mod using bondo..it is pretty easy to apply, but get ready to do a lot of sanding. Link to comment Share on other sites More sharing options...
NewLegGT67 Posted January 11, 2008 Share Posted January 11, 2008 Bondo + Sandpaper + Paint = I can't remeber the type of grit for the sandpaper. Home Depot should be able to hook you up. I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3. Link to comment Share on other sites More sharing options...
Pedestrian Posted January 12, 2008 Author Share Posted January 12, 2008 Thanks for the feedback guys, it probably won't be too bad after all. Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted January 14, 2008 Share Posted January 14, 2008 Just sell it to me, problem solved. Link to comment Share on other sites More sharing options...
Pedestrian Posted January 16, 2008 Author Share Posted January 16, 2008 Hmm, thats actually half way tempting Link to comment Share on other sites More sharing options...
ejoy1220 Posted January 18, 2008 Share Posted January 18, 2008 I too have a severely crackes RBS lip that I'm going to repair and rebuild this spring, and I used to live in Amherst...wierddddd I'm going to fiberglass it with some fiber cloth, resin jelly, sand, bondo, sand, bondo, sand, bondo, sand, filler primer, sand, prime, paint Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted January 18, 2008 Share Posted January 18, 2008 Hmm, thats actually half way tempting And I live in Ma Link to comment Share on other sites More sharing options...
qikslvr Posted January 18, 2008 Share Posted January 18, 2008 Get it so the crack is lined up as best you can and do the majority of the glass work from the back side to build strength so it won't crack again, then just use a little firba-glass or bondo to fill the crack on the face. This will save hours of sanding and refilling. Again structure on the back side and cosmetics on the surface. Let's kick this pig! Link to comment Share on other sites More sharing options...
Pedestrian Posted January 18, 2008 Author Share Posted January 18, 2008 Awesome, thanks for the feedback guys. I think I'll be able to tackle this, but not until its warmer Link to comment Share on other sites More sharing options...
03LegacyWgn Posted January 18, 2008 Share Posted January 18, 2008 what you want to do is, go to your local auto parts store or auto body supply shop and get a 2 part epoxy suitable for the substrate, the person helping you should know the proper steps to make it work good. you dont want to stick with just bondo, bondo will shrink a little bit and if it is placed in the lip, the lip may flex with day to day driving or if its bumped by a parking median etc.. it will crack then back to square one. that is my easy way of doing it, working in a body shop for just over 2 years has helped me a lot in doing the small tasks such as this, hope this works out for ya and let me know how it turned out and what way you used. 03 BH Mods: Group A Alt & Crank Pullys and end links, CIA, JDM L7 Grille, JDM HID lights, JDM rear tails Stromung CBE, KYB GR2's W/ H&R springs. Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted January 19, 2008 Share Posted January 19, 2008 Don't help him . Link to comment Share on other sites More sharing options...
