Yucky08GT Posted October 26, 2014 Share Posted October 26, 2014 OK everyone I need a little help here. The throwout bearing in my 2008 Legacy GT Limited went out last week. I took the tranny out of the car and the snout is thoroughly thrashed. I know the only solution other than a new tranny is the TSK3, I just wanted to post a couple photos here and see if you all thought this thing was too far gone for that repair. Link to comment Share on other sites More sharing options...
apexi Posted October 26, 2014 Share Posted October 26, 2014 I'm not familiar enough with the tsk3 and tob operation to say for sure myself, but after reading the thread below and some others, I think there is hope. It sounds like the tsk3 kit only needs a small amount of snout to work, enough for the set screw at the very end to bite into. Hopefully someone else will chime in with a definitive answer, but like I said it looks like it could work. http://legacygt.com/forums/showthread.php/throw-out-bearing-failure-156181.html?p=3286057 *One more quick note. In the thread below, the OP mentions contacting the company that makes the TSK3 kit and asking them if there was enough snout material left to use the TSK3 kit (see posts #16-20). You could try showing them your pictures and seeing what they say. http://legacygt.com/forums/showthread.php/clutch-transmission-issue-bad-noises-190810.html company that makes the TSK kit http://pdmusa1.com/contact-us.aspx Link to comment Share on other sites More sharing options...
Yucky08GT Posted October 27, 2014 Author Share Posted October 27, 2014 Thanks so much for the response! I had searched the forums looking for info on this but I never found the thread you linked to. This answered all my questions perfectly, I'll contact the company too and see what they think. Thanks again! Link to comment Share on other sites More sharing options...
Max Capacity Posted October 28, 2014 Share Posted October 28, 2014 That's pretty nasty looking. Let us know what happens. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Yucky08GT Posted October 28, 2014 Author Share Posted October 28, 2014 Yeah it's pretty ugly. I pulled the pressure plate and disc last night, there's chunks of the snout, pieces of throwout bearing and shavings everywhere. The solution I went with for the clutch replacement was fjk1001 from Exedy with the ff502 flywheel. I'm going on vacation Friday for ten days and won't be fixing this until after I get home but I'll keep updating this thread as I make progress. The clutch itself didn't look that bad, it hadn't been slipping and there's a fair amount of friction material left and no glazing, bluing or cracking on the pressure plate or the flywheel. Doing the full meal deal replacement is more of an ounce of prevention, pound of cure sort of thing. Just makes sense to do it when it's torn down this far anyway. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 28, 2014 Share Posted October 28, 2014 Yes, makes sense to replace the clutch at this time. You can have the FW turned, that will give the new disc the best chance for a long life. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Yucky08GT Posted October 28, 2014 Author Share Posted October 28, 2014 You're talking about turning the new flywheel before I even install it right? Or are you referring to reusing the stock flywheel? I kept getting conflicting info as to whether my car had a single or dual mass stock flywheel, Exedy said it was dual mass but I saw a lot of other places that said single mass was used from 07 on. Either way I figured the FF502 lightweight wasn't a bad idea so I just went for it. I've got end email in to pdm to make sure the tsk3 is going to work for me as well, I'm pretty sure it will but I want to check before I order it. Link to comment Share on other sites More sharing options...
Ein3000 Posted November 6, 2014 Share Posted November 6, 2014 I am replacing my clutch next weekend and ordered a tsk kit just incase. What noises/vibrations were you getting with your torn up snout? Link to comment Share on other sites More sharing options...
GTEASER Posted November 6, 2014 Share Posted November 6, 2014 Yeah, I see a new tranny in your very near future. That snout is waaaayyy too far gone to even use the TSK kit to fix that carnage. The TSK is just a steel sleeve for the tob to run on instead of running on the aluminum snout. You're gonna need a new tranny or bell housing section of the case. Half the snout is gone and IMO not repairable. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
compsurge Posted November 6, 2014 Share Posted November 6, 2014 It looks familiar to one a year or so ago that was salvageable. Your best bet is to contact the TSK3 customer support and give them measurements of the remaining quill material. Link to comment Share on other sites More sharing options...
Yucky08GT Posted November 6, 2014 Author Share Posted November 6, 2014 The only real issue I had before the throwout bearing failed was when I had the clutch pushed in the bearing howled pretty loudly. The snout should be fine, I emailed the company and talked to Joel about it, I sent him the pictures and he said it will work perfectly. Apparently the kit only needs 3/4 of an inch of snout in order to work, he said they've saved hundreds of cases this way. Link to comment Share on other sites More sharing options...
GTEASER Posted November 6, 2014 Share Posted November 6, 2014 Really? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
FJuan Posted November 6, 2014 Share Posted November 6, 2014 Yup, that snot is way too gone. The TSK is not going to work. You'll need to order a new bell housing. Sorry, but that's the truth. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Yucky08GT Posted November 6, 2014 Author Share Posted November 6, 2014 I appreciate your candid response. I've never run up against an automotive issue I couldn't fix so I'll let you all know how awesome it works when I'm done. Also I'll share any additional work I may or may not have to do to make the TSK work with my ruined snout. Link to comment Share on other sites More sharing options...
FJuan Posted November 6, 2014 Share Posted November 6, 2014 You'll be super lucky if you can get the slide fit on the snot. More than likely, it's going to fail, because of how much metal is missing from the snot already. IMO, I wouldn't trust it and just buy a new bell housing. That snot is just way past the point of repair. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
kzr750r1 Posted November 6, 2014 Share Posted November 6, 2014 New Bell Housing and do the snout reinforcement. Unless you like beating yourself up taking your transmission in and out. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 6, 2014 Share Posted November 6, 2014 As I understand it after all these years, the TSK snout kit only works if your snout is damaged. Buying the kit for a good snout does nothing. The TOB ID is the same size on the TSK3 kit as on the stock snout. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
compsurge Posted November 6, 2014 Share Posted November 6, 2014 I believe the TSK3 is oversized on the ID when compared to the stock bearing. The shroud fit on my scoured, but otherwise undamaged, snout just fine. Link to comment Share on other sites More sharing options...
Akasa Posted November 6, 2014 Share Posted November 6, 2014 The TSK3 Snout should fit on an undamaged snout just fine, I plan on doing that with mine. Link to comment Share on other sites More sharing options...
FJuan Posted November 6, 2014 Share Posted November 6, 2014 The TSK TOB is slight larger compared to OEM, since it has to slide over the sleeve. An OEM will not fit over the sleeve. Therefore, the TSK will fit on the stock snot, not sure why would you do that though. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Yucky08GT Posted November 6, 2014 Author Share Posted November 6, 2014 The TSK is meant to prevent the scoring and damage to the snout just as much as it is meant to repair it. Any time you have the transmission out it is a good idea to install this kit as a preventive measure. The stock aluminum snout is very soft and easily scores and causes TOB problems, the TSK is much harder machined stainless steel and will not wear like the aluminum does. I've seen pictures of other transmissions with more of the snout gone than mine, and the kit worked for them. Like I said I emailed my pics to Joel with PDM USA and he said it would work just fine so we'll see. I'm ordering the kit soon so when I get home from Maui I can start putting everything back together. Link to comment Share on other sites More sharing options...
SBT Posted November 6, 2014 Share Posted November 6, 2014 As others had mentioned, you'll need to check with PDM to see what their recommendation is going forward. msprank has a picture somewhere of one that looks worse than, or at least as bad as, yours, and the TSK3 worked fine once they got the bits cleaned up. So it may be salvageable with a TSK3 repair. OTOH, if it's is too damaged to "fix" with the TSK3, you'll have to source both transmission halves and donor your gearset and internals into it. The 5MT doesn't have a front case like the Spec B and STI transmission do. However it works out, good luck. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
kzr750r1 Posted November 6, 2014 Share Posted November 6, 2014 Comments from msprank about getting this done before it gets wasted is where I'm coming from. But your in it now... So good luck to you, I'd be getting blast plates as well if in this situation. Link to comment Share on other sites More sharing options...
SBT Posted November 6, 2014 Share Posted November 6, 2014 As I understand it after all these years, the TSK snout kit only works if your snout is damaged. Buying the kit for a good snout does nothing. The TOB ID is the same size on the TSK3 kit as on the stock snout. I used it as a preventative measure to ensure the structural integrity of the snout in case of premature (or catastrophic) failure of the TOB. Many have chosen to go this route. And negs mate, the TSK3 TOB is oversized because it has to go around the TSK Quill which is larger than the trans snout. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted November 7, 2014 Share Posted November 7, 2014 6MT > TSK. Tits mcgee Link to comment Share on other sites More sharing options...
