David E Posted April 10, 2013 Share Posted April 10, 2013 Has anyone tried to polish the clear instrument cover? Thinking of trying one of the headlight kits. Figure as long as I don't heat up the plastic it might work. Link to comment Share on other sites More sharing options...
ThatGuyFromAus Posted April 10, 2013 Share Posted April 10, 2013 Meguiars PlasticX great for removing scratches from plastic should polish it up good Link to comment Share on other sites More sharing options...
Bandit240 Posted April 10, 2013 Share Posted April 10, 2013 I've used Meguiers clear plastic cleaner and polish on mine before. Made a huge difference, but then again my car had sat for 5 years and everything was nasty. Link to comment Share on other sites More sharing options...
mailman Posted April 10, 2013 Share Posted April 10, 2013 idk about polish, but mine cleaned up great with just soap and water. It had no visible scratches or gouges or the like, just 16 years of dirt. Link to comment Share on other sites More sharing options...
Hemingway Posted April 10, 2013 Share Posted April 10, 2013 Since it is sealed, it is likely just the outside that is dirty. You can easily remove the trim around it (4 Phillips head screws) for extra cleaning without removing it (which can also be done with four more screws and unplugging four wire harness connectors). I would NOT recommend opening it up for cleaning... Link to comment Share on other sites More sharing options...
Zues Marine Posted April 10, 2013 Share Posted April 10, 2013 opening it shouldnt be a big deal, thats how you access the gauges anyhow Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 10, 2013 Share Posted April 10, 2013 Its isn't that that sealed. No rubber or foam. Just tight fitting plastic and 2 pathetic bandings. Haha im thinking of wrapping the plastic inner housing (the piece with gauge holes) in cf. As ricer as that is Link to comment Share on other sites More sharing options...
Zues Marine Posted April 10, 2013 Share Posted April 10, 2013 way less ricer than what i used to have: http://i161.photobucket.com/albums/t232/wakeboardingguy/SL-i/DSCN0384.jpg gross. but ive thought about that before too, get , i think the clear carbon fiber overlay may look better.. Link to comment Share on other sites More sharing options...
PorkchopSandwiches Posted April 10, 2013 Share Posted April 10, 2013 Has anyone tried to polish the clear instrument cover? Thinking of trying one of the headlight kits. Figure as long as I don't heat up the plastic it might work. Avoid using a headlight kit on that lens. They are far too abrasive. Austrailian's suggestion should be best. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 10, 2013 Share Posted April 10, 2013 How did you get that part chrome? Link to comment Share on other sites More sharing options...
David E Posted April 13, 2013 Author Share Posted April 13, 2013 Thanks for the Plast-X tip. Ended up using the Plast-X on the foam ball that came with my headlight restoration kit. Tried just using a microfiber towel but that wasn't working. Took several times, was careful not to stay on one spot too long. Before on the left - after on the right. That's just a reflection on the after pic. Now gotta polish the whole thing. Link to comment Share on other sites More sharing options...
ThatGuyFromAus Posted April 14, 2013 Share Posted April 14, 2013 Looks like it worked a treat, I should give it a go on mine Link to comment Share on other sites More sharing options...
jack_keaka Posted April 14, 2013 Share Posted April 14, 2013 finally some answers about this! really need to do the same to mine. been driving me nuts since I've had the car. i have been to nervous to attempt it though as i know how fragile these are after breaking a friends Astra dash cover. Link to comment Share on other sites More sharing options...
David E Posted April 14, 2013 Author Share Posted April 14, 2013 Just take your time so the plastic doesn't get hot. I didn't count, but I bet I started and stopped at least a dozen times. The Plast-x drys out quickly when you are using the foam ball. I used more of it than I would have guessed, but it was a pretty good scratch. Link to comment Share on other sites More sharing options...
