Aodhan Posted October 11, 2010 Share Posted October 11, 2010 So I tried the search function already with no luck I have a 06 GT Sedan running H-techs and I was wondering if any one has tried a 235/45/R17 tire while running these springs. Currently I am running a 215/45/R17. I know the 235 will be a little wider, think I will run into any rubbing issues.? The reason I as its that my 235 tires are my winter tires and I am trying to figure out if I should throw my stock springs back on. Thanks, Aidan Link to comment Share on other sites More sharing options...
BagheeraLGT Posted October 12, 2010 Share Posted October 12, 2010 ive got H techs on kyb struts and no rubbing with my setup: 18x7.5 +48 wrapped in 225-40-18..... not your exact question but some info for ya. currently i have some rub but its because my struts are beyond dead. before they completely leaked, i had no rub. Link to comment Share on other sites More sharing options...
Aodhan Posted October 12, 2010 Author Share Posted October 12, 2010 Thanks for the post. I am still on stock struts with 65k on the car. I am thinking I may as well just throw the stock springs back on and not worry about it. Link to comment Share on other sites More sharing options...
burnout8488 Posted October 12, 2010 Share Posted October 12, 2010 Not that this helps considering you already own them, but winter tires generally should be skinnier than your summer setup. 235 is pretty meaty for a Legacy winter setup; your car will cut through the snow much better with 215s and generally have better traction. Link to comment Share on other sites More sharing options...
Aodhan Posted October 12, 2010 Author Share Posted October 12, 2010 Not that this helps considering you already own them, but winter tires generally should be skinnier than your summer setup. 235 is pretty meaty for a Legacy winter setup; your car will cut through the snow much better with 215s and generally have better traction. Haha, I was wondering when that was going to be pointed out. I understand that a 215 would be better, but I got the 235's new for free so could not really argue, I know they wont be as good as a 215 but I am sure they will still be a bit better then running an all-season...........or am I wrong in assuming that? Link to comment Share on other sites More sharing options...
zvilly Posted October 17, 2010 Share Posted October 17, 2010 I have H-techs and running 18x8.5 +48 rota g-forces, with 235/40/18 tires, no rubbing at all. You should have no issues. Link to comment Share on other sites More sharing options...
Aodhan Posted October 17, 2010 Author Share Posted October 17, 2010 I have H-techs and running 18x8.5 +48 rota g-forces, with 235/40/18 tires, no rubbing at all. You should have no issues. Awesome to hear, thanks for the heads up. Link to comment Share on other sites More sharing options...
burnout8488 Posted October 19, 2010 Share Posted October 19, 2010 Yeah, as long as there's siping in the tire I'm sure you'll still be better off than an all season. Can't argue with free though! Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted October 19, 2010 Share Posted October 19, 2010 i had that set up two winters ago with h-techs. you shouldnt have a problem. also when the wheel goes up its doesnt go up Staight '|' it goes up at an angle inwards the car '/ Left' '\ right' my current tires are 225/45/18 and the rims have an agressive offset i am almsot flush. and it doesnt rub at all. Link to comment Share on other sites More sharing options...
