scottyjneilson Posted March 29, 2011 Share Posted March 29, 2011 so being new to this legacy and all I want to do it right and not screw it up. I am slowly adding to the looks of the ride but upon running through the sticky section found that this may be a likely option for me on the performance side of things. Any opinions on this intake combination would be great. http://www.avoturboworld.com/avoshop/panel-filter-p-3.html http://www.ravspeconline.com/shop/catalog/product_info.php?cPath=1_29_76&products_id=1909&manufacturers_id= Link to comment Share on other sites More sharing options...
sulk Posted March 29, 2011 Share Posted March 29, 2011 Stick with the avo high flow, probably the best one out there. Link to comment Share on other sites More sharing options...
scottyjneilson Posted March 30, 2011 Author Share Posted March 30, 2011 Avo high flow it is Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 4, 2011 Share Posted April 4, 2011 AVO all day! Link to comment Share on other sites More sharing options...
scottyjneilson Posted April 7, 2011 Author Share Posted April 7, 2011 just put the AVO in love it ! Link to comment Share on other sites More sharing options...
OhBe1 Posted April 9, 2011 Share Posted April 9, 2011 Which actually is CAI... 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
scottyjneilson Posted April 9, 2011 Author Share Posted April 9, 2011 Oh... I honestly did not know the stock intake with a high flow filter was considered a CAI... well as the original post says I am new so thanks for the info OhBe1. Just removed the snorkus while I was doing headlight clearing and reset my ECU just today. It is performing way better now. A little more ummph on the low end as I percieve... Link to comment Share on other sites More sharing options...
sulk Posted April 10, 2011 Share Posted April 10, 2011 Which actually is CAI... huh? the high flow is a panel filter that replaces the stock filter. So unless you're calling the stock setup a cai than? AVO does sell a cai, but its marketed towards the lgt, but i think it does work on 2.5i not too many NAs seem to be running it though. Link to comment Share on other sites More sharing options...
scottyjneilson Posted April 10, 2011 Author Share Posted April 10, 2011 So what is it then ? CAI or NOT. I have the AVO high flow drop in panel with the stock intake system... Link to comment Share on other sites More sharing options...
OhBe1 Posted April 10, 2011 Share Posted April 10, 2011 Stock is CAI. Might not be high flow, but it gets air from outside the engine room. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Abandonhope16 Posted April 20, 2011 Share Posted April 20, 2011 So, I've been out of the part buying dept for a while now that my LGT is gone. Is AVO still the way to go? Thats what I had on mine and I wanted to confirm that it would work on an N/A. Also, whats this business of resetting the ECU; how does one go about that? Link to comment Share on other sites More sharing options...
scottyjneilson Posted April 20, 2011 Author Share Posted April 20, 2011 yep AVO drop in will work on our 2.5i's. As far as the ECU reset... Just disconnect your negative wire from your battery for 15 to 30 minutes hit the brakes and such to get rid of any stored charge... reconnect the negative wire to battery. Let car warm up to opperating temp( do not hit gas pedal while warming up) Once warmed up take it for a spirited drive(be aggressive on the pedal) Doing this got rid of the lag I felt after I put the avo in and removed the snorkus. I chalk up the ECU reset to being similar to reseting your Home computer once you have uninstalled a program. Basically resets your car computer so that it becomes used to the added increase of airflow to the engine... Link to comment Share on other sites More sharing options...
Abandonhope16 Posted April 20, 2011 Share Posted April 20, 2011 Great. Thanks! Any preferred vendors? Seems it runs about $55 not matter where you look. Link to comment Share on other sites More sharing options...
scottyjneilson Posted April 20, 2011 Author Share Posted April 20, 2011 I ordered mine straight from AVO. It ships out from somewhere near seattle. Shipping is very quick. http://www.avoturboworld.com/avoshop/intake-parts-c-6_7_8.html Link to comment Share on other sites More sharing options...
spongemonster Posted April 21, 2011 Share Posted April 21, 2011 There's also the Perrin foam filter if you're not a big fan of cotton gauze filters. http://www.perrinperformance.com/products/show/234/Drop-In-Air-Filter?category=3&model=10 Link to comment Share on other sites More sharing options...
iw_dubs_721 Posted April 23, 2011 Share Posted April 23, 2011 Has anyone tried a Perrin drop-in in a N/A? How is it compared to the AVO drop-in? Link to comment Share on other sites More sharing options...
scottyjneilson Posted April 24, 2011 Author Share Posted April 24, 2011 Both are cheap enough buy both ! Link to comment Share on other sites More sharing options...
katalyst Posted April 24, 2011 Share Posted April 24, 2011 i've read of issues members have had in regards to the perrin filter due to the oil that it needs Link to comment Share on other sites More sharing options...
scottyjneilson Posted April 24, 2011 Author Share Posted April 24, 2011 i've read of issues members have had in regards to the perrin filter due to the oil that it needs You do have a point there. AVO requires no oil ! which is good! Link to comment Share on other sites More sharing options...
sweet-subaru Posted April 25, 2011 Share Posted April 25, 2011 snorkus ,whats a snorkus??? Link to comment Share on other sites More sharing options...
scottyjneilson Posted April 26, 2011 Author Share Posted April 26, 2011 snorkus ,whats a snorkus??? The Big A$$ water jug looking thing that is on the bottom of your intake aka "intake Silencer" Makes your engine louder when you step on it. I usually get a more throaty sound around 3k rpms Link to comment Share on other sites More sharing options...
mikew1484 Posted April 26, 2011 Share Posted April 26, 2011 http://www.cosmoracing.com/productinfo.asp?cid=150&pid=1952 Cosmo makes a pretty nice CAI as well for them, has a really nice sound to it as well. Link to comment Share on other sites More sharing options...
scottyjneilson Posted April 26, 2011 Author Share Posted April 26, 2011 http://www.cosmoracing.com/productinfo.asp?cid=150&pid=1952 Cosmo makes a pretty nice CAI as well for them, has a really nice sound to it as well. You will need a tune for full benefits for this kind of setup. Link to comment Share on other sites More sharing options...
mikew1484 Posted April 26, 2011 Share Posted April 26, 2011 Well snap, I better get a tune I was planning on waiting until I got Headers, and possible exhaust...just researching at this point. So that AVO cans are direct bolt on for the 2.5i's? They cause any problems does anyone know (preferable from experience)? Link to comment Share on other sites More sharing options...
katalyst Posted April 26, 2011 Share Posted April 26, 2011 no problems as far as i know, N.sane has them on his car sound awesome Link to comment Share on other sites More sharing options...
