BanzGotBoost Posted July 19, 2010 Share Posted July 19, 2010 Hey guys, I'm sure some of you have seen my other post, I'm debating whether or not to get this new ECU put in tomorrow or not. Will I run the risk of damanagin the car with a stock ECU and an aftermarket TMIC, Up pipe, and Down pipe? I might get the ECU changed tomorrow but I have no idea when I can get a tune in since the cable I have right now isn't working. Any and all help is greatly appreciated :spin: Link to comment Share on other sites More sharing options...
thebigevilfoot Posted July 19, 2010 Share Posted July 19, 2010 Just don't run it hard. I had quite a little bit of time in between my parts and tune and my car was fine. Link to comment Share on other sites More sharing options...
BanzGotBoost Posted July 19, 2010 Author Share Posted July 19, 2010 from what I heard from the subaru tech, adding the new ecu will reduce the boost down to 13 instead of the current tune of 17, and my fuel consumption might be messed up, does that sound right? i think at this point im gonna keep running on the "damaged" ecu until I can find a tactrix to borrrow and get the rom off of the current ecu and put it on the new ecu. has anyone had any issues with the tactrix cable and windows 7? Link to comment Share on other sites More sharing options...
sarasube Posted July 19, 2010 Share Posted July 19, 2010 had my ecu changed due to fan relay switch. went for opensource tune and tuner could not get the boost past stock (13psi). he will try prodrive boost solenoid. will update. thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted July 19, 2010 Share Posted July 19, 2010 I'm not good with this stuff, but don't you use a local Tuner ? I have someone local. Try Tuning Alliance.com of Infamous here somewhere. I think they are both vendors. Look around you should be able to get one of them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
scoobydoobie Posted July 19, 2010 Share Posted July 19, 2010 I'm not good with this stuff, but don't you use a local Tuner ? I have someone local. Try Tuning Alliance.com of Informous here somewhere. I think they are both vendors. Look around you should be able to get one of them. Informous? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 19, 2010 Share Posted July 19, 2010 Fixed it....must be spell check..... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BanzGotBoost Posted July 19, 2010 Author Share Posted July 19, 2010 yeah the previous owner had infamous put a log on, i sent him a pm to see if he can resend it to me, i know he's busy and is sorting through his pm's, ive decided to wake til i get back to school in wv to get the new ecu Link to comment Share on other sites More sharing options...
Max Capacity Posted July 19, 2010 Share Posted July 19, 2010 Personally, I'm not good with all this tuning stuff. I leave that to the Pro's, I'm lucky enough to have a Tuning Alliance close to me. He's been over the house a couple of times. These guy's are worth there weight in gold. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BanzGotBoost Posted July 19, 2010 Author Share Posted July 19, 2010 yeah im gonna get a tactrix and get someone to walk me through it, i think the ecu should be fine until i get it replaced sometime next week Link to comment Share on other sites More sharing options...
