Silinc3r's 05 GT SWP
Silinc3r
Picked this beauty up over the weekend in Atlanta. Was very lucky to find this in Atlanta for the price and low miles. Its not the Limited but it is everything else I wanted, color, 5spd, GT, black interior. Also came with a fair amount of goodies :cool:.
2005 Unlimited GT 5spd Satin White Pearl
82033 miles upon purchase
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0675.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0673.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0672.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0671.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0669.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0668.jpg
I am guessing this was done to keep the car from throwing a O2 code
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0664.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0663.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0661.jpg
If anybody recognizes this car please let me know because I would like to know what all has been done. Car was originally from Virginia.
Mods: As of 4/10/17
Engine:
Grimmspeed intake
Perrin turbo inlet
Samco BOV hose
STi Genome strut bar
Dressupbolts kit, titanium true burned
Bulletproofed black TMIC
Zero Sports cool action II intercooler splitter in BLUE!!
Zero Sports radiator shroud
Zero Sports alternator shroud
Zero Sports 1.3 BAR rad cap
Zero Sports 1.1 BAR expansion tank cap
Zero Sports V-Effector Voltage Stabilizer & V-Earthing Ground
GFB response BOV
AVO throttle body hose
Moroso dual catch cans
Glowshift oil sandwich adapter plate
KillerB windage tray and oil pickup tube
Exhaust:
Megan racing dual tip muffler
Tomei Expreme (DEI tit wrapped)
Tsuedo cast bellmouth down pipe (DEI wrapped)
Power:
Tuned to 19 PSI open source -DrunkmannTuning
"Stage 2"
VF52
DW65C
GS EBCS
Hallman manual boost controller (hybrid setup)
Suspension:
BC BR coilovers
Perrin pitch stop
Group-N motor mounts
Wheels:
Enkei TS10 18x8 Gold!!!!
H&R 5mm spacers
H&R extended studs
Bridgestone Potenza s-04 Pole Postion 225/45/18
JDM STi lug nuts
Stopping:
Brembo calipers up front
Stoptech rotors and Stoptech pads upfront
Stoptech slotted rotors and pads in rear
Gforce lines
Grimmspeed master cylinder brace
Interior:
Tommy Kaira, Heavy Baby shift knob
2006 Spec B interior
Zero Sports 350mm steering wheel
2006 spec shifter surround with number plate 419/500
Crown Royal shifter boot
JCSpod dual A pillar
AEM wideband
Prosport boost gauge
FastWRX pre/post intercooler temp guage
Defi triple gauge pack, oil temp, oil pressure, water temp
Kenwood DNX571HD
JDM dual HVAC setup
JDM hazard
Factory STi short shift
STi push start button
Factory underseat sub X2!!
Exterior:
Tint-20%
JDM STi Genome grill
JDM aero spats
JDM strakes
JDM headlight garnish
JDM rear tail light garnish
L7 badge
rebadged Spec B
BaysonR LGT front lip
R-Rev CF rear roof spoiler
R-Rev CF scoop bulge
R-Rev switchbacks
R-Rev reverse lights
R-Rev license plate lights
Dynoed at Emerald Coast Motorsports 255hp/277tq
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG1758.jpg
Edited by Silinc3r
current mods
And you can see this how?
you can see it in the picture with the plug that has the resistor in it
yea I am pretty sure it needs a tune, its a little rough when I step on it but other than that no problems and I got 26 MPG from Atlanta to Mobile and that was with doing some power trials
Pretty sure that's an aftermarket DP. In the EGT sensor harness picture with the resistor - you can see a WBO2 bung welded in and lack of upper cat that would be present in an OEM DP.
Also, you will want an engine cover if you plan on running that OEM TMIC. Also should "bulletproof" it since you are likely running a Stage 2 tune, (BarManBean is working on a new batch). If you need an OEM engine cover I happen to have one that's perfect I'm willing to part with :) The engine cover helps seal the splitter to the TMIC.
Haha you are so right...I retract my previous statements. I did not look past the sensor in the picture. Good call. Definitely aftermarket.
Are you asking me or just showing me that I was correct in my thought, except its EGT and not O2:redface:. Thanks none the less
And Catalyst I might have to take you up on that
So does anybody recognize this vehicle?
Knowing Max, it was a rhetorical question I'm sure.
Nice purchase.
My .02....
Tune, which has already been stated many times so far.
Get your uppipe and downpipe wrapped up. You should also, IMO, get a turbo blanket or at the least a turbo heat shield. You have LOTS of heat coming off all 3 parts and need to get your under hood temps under control. Your intercooler I'm sure is getting heat soaked like a mofo.
Question for you all.
Do you see the rubber coolant hose that makes a hump over the intake tube?
It is turning white. This is due to coolant. Do these hoses crack or seep at all? Mine is doing the same thing and there are no visible leaks at the union where it meets the hard line.
Just curious if people see this problem alot on that specific hose.
Thanks.
Huh nice catch, didn't reall pay much attention when at the dealership. Noticed it but didn't think about it. However this is for the expansion tank line only and should only see heat if there is an over heat or fire. Also drove the car from Atlanta to Mobile and didn't have any problems so I'll keep an eye on it incase there is a pin hole in the hose. Thanks for pointing it out.
  • 3 weeks later...
So little update, have been saearching around on things I need to do after purcahasing the vehicle; oil/filter change, tranny and rear diff fluid change and came across the warranty on the wheel bearings. The innitial warranty was through 08/07/09 and was extended annother 40,000 and 36 months to 08/31/2012. So I went to Subaru dealership and went to ask about it and he showed me that I just missed the expiration but to call SOA and see what they can do. The part is only 135 dollars so I might just end up doing it myself as it will just be easier and cheaper for me to go that route but I'll still check.
Also upon pulling up my VIN# he was able to show what all had been done to the vehicle adn it showed the right rear had all ready been replaced. ALSO I found the option that where equiped and found a nice little goodie- T5A or also known as a Short Throw Shifter.
So for anyone interested in buying any SUBARU grab the VIN# and go to a dealership and have them pull up the information. I didn't think/know about it when I was buying the car but I know now. CARFAX did not show all of this information.
  • 3 months later...
So a small update. Finally got some stock splash guards which I am a fan of. Not really into the RA mud flaps.
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0901.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0888.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0889.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0890.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0891.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0892.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0895.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0896.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0897.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0898.jpg
http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0900.jpg
And trying to decide between the STi Enkei golds or Prodrive GT1s
I know you said you like the splash guards, but better take them off now as it will start to rust under and behind it in a few years, unless you don't see snow and salt but then you still get rain.
All of my 3 previous cars had rust with those slash guards
