Gt_Legacy Posted December 7, 2015 Share Posted December 7, 2015 so I recently just got done with my wrecked rebuild on my 99 lgt. I finally got a temp tag for it so I decided to hit the road. I went about 2 miles and it felt like my car was stalling by 4 gear so I slowed down and pulled over and it was barley keeping idle, bogging down when I hit the gas and back firing. I was able to get it towed home. me and my buddies originally thought it was going to be the tps since we adjusted it earlier thinking it was a fix but it wasn't. anyway we got the tps adjusted properly. checked the spark plugs. one side was super black and the other side was not as bad. remembering that we swapped the fuel rail with injectors ect. we decided to swap them back. we drove it up and down the street once thinking we fixed it. the next day we test drove it again and it barley went up and down my street twice. since then I replaced the fuel filter still having the same problem and now im a little clueless. any help is appreciated thanks. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 8, 2015 I Donated Share Posted December 8, 2015 What codes are coming up (check engine light)? That is probably a good place to start. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Gt_Legacy Posted December 8, 2015 Author Share Posted December 8, 2015 What codes are coming up (check engine light)? That is probably a good place to start. that's my biggest issue, I have no codes. I did have a tps code when it wasn't aligned properly but it went away after it got lined back up. Link to comment Share on other sites More sharing options...
FLlegacy Posted December 15, 2015 Share Posted December 15, 2015 You should make sure your injectors aren't stuck or sticking, you should be able to verify with a stethoscope, I would think the O2 sensor cel would pop up but the older cars sometimes have a lot of variance in the allowable readings and need a couple of complete drive cycles to set a code. You should also check the resistance in the plug wires just to be certain. If that checks out verify timing, and clean the plugs run the engine then check the plugs again. Link to comment Share on other sites More sharing options...
Gt_Legacy Posted December 16, 2015 Author Share Posted December 16, 2015 You should make sure your injectors aren't stuck or sticking, you should be able to verify with a stethoscope, I would think the O2 sensor cel would pop up but the older cars sometimes have a lot of variance in the allowable readings and need a couple of complete drive cycles to set a code. You should also check the resistance in the plug wires just to be certain. If that checks out verify timing, and clean the plugs run the engine then check the plugs again. we didn't try the injectors but im not too sure if that is the problem or not. im starting to think that the ecu got re mapped some how or something because i have 4 emissions systems not ready, and i dont think they have been ready since i owned the car. the systems are 02, egr, maf and one more thing. i do have an after market exhaust so it could be the case. i recently decided to check the cat to see if it was flowing properly and because i also noticed some platinum coming out of my tail pipe. so i dropped the exhaust and cut the cat off and sure enough there was a hole blown through the cat with the plastic mesh of some sort melted and all sorts of mangled. we bought a new cat but had some issues with lining it up and re welding. we will try again this weekend and see what happens. Link to comment Share on other sites More sharing options...
FLlegacy Posted December 17, 2015 Share Posted December 17, 2015 That wouldn't explain running rich on only 2 cylinders. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Gt_Legacy Posted December 17, 2015 Author Share Posted December 17, 2015 we replaced the fuel rail on that side to its original one because we thought it was causing an issue previously Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 19, 2015 I Donated Share Posted December 19, 2015 that's my biggest issue, I have no codes. I did have a tps code when it wasn't aligned properly but it went away after it got lined back up. You do have codes. They might not be current codes, but there is almost certainly one (or more) pending code or history code. Some cheaper scanners don't pull up history or pending codes....so if your scanner won't do that then find one that will. Also the datastreams might be helpful to look at if you're able to access them. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Gt_Legacy Posted December 19, 2015 Author Share Posted December 19, 2015 So here's my update, got the cat welded on properly so we started it up while it was still on jacks and it ran perfect even up at idle temp. But then when I started to rev the rmp gauge would go up to 2k then drop to 0 while I'm still reving. We decided to drop the car and take it for a test drive, after we dropped it we tried to start it and the battery died in that time, threw it on the charger and once it charged a bit I tried again and it wouldn't crank because the battery was too dead but after I stopped trying the car alarm starting going off and it did it multiple times and while it was going off my raido and my abs light would die while the horn was going off. I'm guessing I have a serious electrical problem because I already found a bunch of jank wiring. Any help now would be appreciated Sent from my XT1254 using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted December 20, 2015 Share Posted December 20, 2015 You need to fix your charging problem and ensure your battery is good, then you can start troubleshooting the other issues. A good scanner will plug right into the OBD port and read you the live data from the sensors but that requires a good battery and functioning alternator. Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
Gt_Legacy Posted December 28, 2015 Author Share Posted December 28, 2015 i had a really simple fix to this actually, all i did was unplug the keyless entry unit and the alarm stopped and the car started and ran perfectly fine after that. so i just have a few more kinks to work out then i should be ready to go. Link to comment Share on other sites More sharing options...
