Custom Headers...help???
Hello thanks for looking and please try to read the whole thing. I have a 2005 2.5i with the big single ported manifolds that go to the dreaded long equal length headers with 3 cats and 5 o2 sensors
I put oem legacy gt headers on them and had someone fabricate them to the rest of the exhaust. Putting the dual port headers on a single port heads wouldn't mean it exactly lines up and the stock gaskets would leave a gap so I put on dual port gaskets on with a big hole cut in the middle. The thing is cutting the dual ported gaskets weakened themand now I have a huge leak from the gaskets.
I thought of welding my stock flanges on them so I took it to the guy who did this all to see if hell CNC flanges and that would be $200 and he said he wants to redo the whole thing his way with the flanges but it will be another 1000 if it has his name on it. I'm already in these headers over 600 from this guy and spending it on a 2.5i for a rumble is rediculous. also the headers are cast iron so nobody would be able to weld to it so I've been told
Long story short. I think I only have 2 options since the only problem with the leak is in the gaskets. So either A) put an adapter in using the stock gasket but more like how I drew it out pictured below, or B) throw everything away and go back to stock:((((( I saw ONE person do this with lgt headers on a different forum but can't find the link so I was almost certain it could be done. So I'm looking to see if any local places could do it cheaper cuz it doesn't seem that hard to make a flange. Or will someone on here reading this think they can make something kinda in the picture but better?
http://img.tapatalk.com/d/14/06/19/ze3ygy2e.jpg
http://img.tapatalk.com/d/14/06/19/pu3aqu7e.jpg
http://img.tapatalk.com/d/14/06/19/ugy9uduh.jpg
These are what the dual ported gaskets are shaped like:http://img.tapatalk.com/d/14/06/19/4umu6ypa.jpg
And these are what my stock gaskets are shaped like so something had to be made that fits both of these kinda how I drewhttp://img.tapatalk.com/d/14/06/19/neqe9equ.jpg
Do you think that'll work? The gasket in the 3rd pic would seem like id need layers and layers if that'll even do it. A guy I know tried it and it stopped it for only 6 months
I don't know if it would hold up but it would be the cheapest way to go as long as you give it adequate curing time. You could also try stacking gaskets to fill the gap. The copper worked for me on a non turbo car (1971 240z). No idea.on how it would work o n a modern car with turbo backpressure.
It's a 2.5i no turbo. Yeah I'll try it everyone tells me double stacking gaskets and sealant would make it worse but never tried it myself
Have someone adapt the flanges on the exhaust manifold by adding metal and then remachining OR you could purchase a LGT header from an aftermarket company and then cut off the flange and reweld on a new one that fits your heads.
To be clear I searched everywhere to find Uel headers that fit my setup and there isn't any. Even if there was there wouldn't be a big enough market for one. The reason I chose the lgt headers was that they have dual ports going into a thicker pipe. Rather than just having 2 skinny pipes going the whole way so I wouldn't be able to adapt to that at all. The lgt headers could have metal added if they are easily weldable
