a.lim Posted April 7, 2008 Share Posted April 7, 2008 i got my throwout bearing and pressure plate replaced by renick subaru @ 18,000 miles due to excessive rattling issues. the rattling went away and i noticed the clutch pedal was a LOT more soft. well bad news, now @ 22,000 miles the same problem is rising. its becoming a concern for me now its only been so long since i got it replaced. anyone else have bad experiences with this? Link to comment Share on other sites More sharing options...
j255c Posted April 7, 2008 Share Posted April 7, 2008 have rattling metallic noise coming from transmission, replacing my clutch beginning of may. Hopefully it didnt snap that engagement U shaped thingy. Some person had similar sounds and his trans was very messed up when they cracked it open. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
kscottw Posted May 16, 2008 Share Posted May 16, 2008 thats exactly what happened to me! My car is in the shop right now getting a new tranny casing cuz my throwout bearing busted thus loosening the clutch and flywheel which then in turn tore up the front of my tranny casing. $2500 later and im good to go. This all happened in one day too, i didnt even see it coming. Link to comment Share on other sites More sharing options...
Guest Posted May 16, 2008 Share Posted May 16, 2008 many reports of t-out grenading the tranny case I replaced it as a preventive measure Link to comment Share on other sites More sharing options...
highlander Posted May 20, 2008 Share Posted May 20, 2008 Mine was failing when I upgraded the clutch. Think the input shaft has some wear on it from the old bearing that isn't visibly obvious, but can be felt through the pedal. Warranty won't cover it now, but it all runs well. Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
atcvader Posted May 20, 2008 Share Posted May 20, 2008 mine just went out. I need to buy a new clutch and tranny. FAKC SH*%! Link to comment Share on other sites More sharing options...
Guest Posted May 20, 2008 Share Posted May 20, 2008 mine just went out. I need to buy a new clutch and tranny. FAKC SH*%! Ouch. How many miles? Link to comment Share on other sites More sharing options...
atcvader Posted May 20, 2008 Share Posted May 20, 2008 90,000. It's about time Link to comment Share on other sites More sharing options...
Guest Posted May 20, 2008 Share Posted May 20, 2008 90,000. It's about time Well, not a time for a new tranny Link to comment Share on other sites More sharing options...
a.lim Posted May 25, 2008 Author Share Posted May 25, 2008 well i guess i have a bad habit of fully engaging the clutch in for too long.. throw out bearing goes out fast like that. so just a heads up.. try to avoid staying engaged in 1st gear on red lights so you can take off faster! Link to comment Share on other sites More sharing options...
FJuan Posted June 16, 2008 Share Posted June 16, 2008 Getting new clutch put in today. Here's what happen. Started to hear a light rattle when pressing the clutch pedal down. After a few stop and goes later the pedal was touching the floor board and a smell of burning grease came from under the car, at this point I know I'm in trouble. Then finally it went to the floor board and stuck there. When the dealer pulled it apart, this is what they found. The bearing was seizing up causing to brake off the fingers of the presure plate. Once the fingers where broken off the presure plate the bearing pressed right through to the disk. Which heated up and caused the smell of burning grease. When you start to hear the light rattle from pressing in the clutch pedal, it's time to replace it, don't wait. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
dr_sharp Posted June 17, 2008 Share Posted June 17, 2008 I hear a light rattle when the clutch is engaged but not in gear (i.e. idling just after startup). Could this be the same issue? lol Link to comment Share on other sites More sharing options...
kscottw Posted June 17, 2008 Share Posted June 17, 2008 I would get it checked out before anything goes awry. Its not good news if it does. Link to comment Share on other sites More sharing options...
