babeatto Posted February 11, 2005 Share Posted February 11, 2005 I can get hold of a bunch of older model Bilstein suspensions. I was wondering if they can be installed into the new legacy perfectly? Any pros and cons about used suspension? thanks. Link to comment Share on other sites More sharing options...
apexjapan Posted February 11, 2005 Share Posted February 11, 2005 I can get hold of a bunch of older model Bilstein suspensions. I was wondering if they can be installed into the new legacy perfectly? Any pros and cons about used suspension? thanks. They won't fit the new Legacy - too different in enough key areas. That is one of the reasons it took a while for new coilovers to appear in Japan for the new Legacy. The only pro for used suspension is the price. The cons: worn/blown dampers sagging springs Though suspension, in general, is sturdy enough that you won't get them in bad shape, it is something to keep in mind. I've seen stock dampers that have lasted 5 years, and I've seen some where one of the dampers only lasted 5 months. Cheers, Paul Hansen http://www.avoturboworld.com http://www.ImGoingToMauiIn6Hours.com Link to comment Share on other sites More sharing options...
babeatto Posted February 12, 2005 Author Share Posted February 12, 2005 Thanks Paul =) Link to comment Share on other sites More sharing options...
iamrazor Posted February 24, 2005 Share Posted February 24, 2005 what do you mean by "older"? I have a BE (00-04) and am looking for bilsteins.... Link to comment Share on other sites More sharing options...
