archer1.8 Posted June 2, 2013 Share Posted June 2, 2013 I had my moms 05 2.5i on 4 jackstands and had it idle there. I was looking to see what wheel bearing was bad. I got a speed sensor CEL and with the ABS light and cruise control blinking. Which I expected. Now the car idles really really low and it stalls when you come to a stop. I cleared the code with my scanner, and pulled the battery. Any ideas? I dont have my laptop to clear the TCU right now. Link to comment Share on other sites More sharing options...
apexi Posted June 2, 2013 Share Posted June 2, 2013 So do you mean the car started running rough and stalling after you had the battery removed? If so, this is normal. 2.5i's are temperamental after the ecu has been reset Link to comment Share on other sites More sharing options...
Blake23 Posted June 2, 2013 Share Posted June 2, 2013 my old 08 2.5i took about 100 miles to re calibrate the ecu after the battery was disconnected.it would constantly die when i came to stop lights.. Link to comment Share on other sites More sharing options...
archer1.8 Posted June 2, 2013 Author Share Posted June 2, 2013 I had it on the jackstand and cleared the code via OBD scanner. Then started it and it ran like crap. Pulled the terminal and did an ECU reset. Still no change Link to comment Share on other sites More sharing options...
Blake23 Posted June 2, 2013 Share Posted June 2, 2013 all you can do is drive it ... it will relearn. Link to comment Share on other sites More sharing options...
