bg. Posted March 17, 2012 Share Posted March 17, 2012 Hi there, my axle fell out of the differential today when I was reefing on some suspension components on my car, fluid leaked out, and I had to press in the axle again. Now that the axle is pressed in, I need to fill the fluid, how do I go about adding fluid? Thanks in advance! Bg. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 17, 2012 Share Posted March 17, 2012 There is a dip stick behind the turbo under the tmic. Make sure the car is level. Check the oil leve and top it off with some 75w-90 gear oil. Then you may want to think about buying some Extra-S Subaru 75w-90 from one of the vendors on here and changing all 3.8 qt's so you knw you have good fluid in there. To drain all the old fluid out you need to jack up the rear of the car after you have broken the torque on the tranny drain plug. I think it's a 70 torx. I needed a 1/2 breaker bar to do mine the first time. There are other fluids that are ok to use too. Both my cars have Amsoil Severgear 75w-90 in them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
wai_pang2 Posted March 17, 2012 Share Posted March 17, 2012 ^ What Max Capacity said. I use the same gear oil. Link to comment Share on other sites More sharing options...
bluesuby Posted March 17, 2012 Share Posted March 17, 2012 It holds about 4 quarts, slightly less. When you jack up the rear you'll drain just about everything. Link to comment Share on other sites More sharing options...
bg. Posted March 18, 2012 Author Share Posted March 18, 2012 Thanks for the thorough answer, Max. I ended up rushing to a store around here and buying buying a couple quarts of castrol syntec 75-90 just to top it off so I can drive around for now. I will be picking up the big torx bit and drain it and fill it with some better gear oil, maybe next weekend. Heck, I might as well do the rear too while I'm at it! Link to comment Share on other sites More sharing options...
mwm5094 Posted March 18, 2012 Share Posted March 18, 2012 ^you will need a pump for the rear in order to get the gear oil back in. Link to comment Share on other sites More sharing options...
