dwiens87 Posted March 28, 2009 Share Posted March 28, 2009 So I replaced my stock H7 low beams with Daniel Stern's recommended Osram Rallye's with ease. However, now that it is dark, I can tell something is very wrong. Both bulbs are lighting up fine but it seems the driver side is pretty dark with a strong beam pointing roughly 10 o'clock. I'm pretty sure, I didn't touch or go near the projection alignment. I just swapped the bulbs. Should i take it in to the dealer to get them adjusted? I can see, its just not....focused? Link to comment Share on other sites More sharing options...
outahere Posted March 28, 2009 Share Posted March 28, 2009 The bulb is probably not properly seated. Link to comment Share on other sites More sharing options...
magnus617 Posted March 28, 2009 Share Posted March 28, 2009 there is a little tab on the bulb that you have to match up with a slot in the headlight. my guess is that it's just seated a little cockeyed in there, an easy mistake to make never, under any circumstances, take sleeping pills at the same time as a laxative. Link to comment Share on other sites More sharing options...
