riceprotein Posted August 11, 2016 Share Posted August 11, 2016 There is no tension on my interior hood release cable. Does anyone have any clue how to manually open the hood? I searched online but each car's hood release is different. I can get a screwdriver up into the general area of what looks like the release mechanism, but I'm lost on what I need to pull or press. Any insight would be appreciated. Link to comment Share on other sites More sharing options...
FLlegacy Posted August 11, 2016 Share Posted August 11, 2016 Try going to the hood and giving it a quick but firm strike withe bottom of your closed hand like you would hit a table while sitting at it. Sometimes the latch sticks and doesn't release the hood. If that is the case get some penetrating oil to lube it. Link to comment Share on other sites More sharing options...
riceprotein Posted August 11, 2016 Author Share Posted August 11, 2016 Yea, I tried that, no luck. The cable is still attacked to the interior release lever and I tried using a pair of pliers to pull on the cable, but it wouldn't budge. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted August 11, 2016 Share Posted August 11, 2016 The cable wouldn't budge or the hood wouldn't pop open when you pulled on the cable? It sounds like you already pulled the lever but the hood will not open. A little elbow grease and you should be able to get it to lift. Link to comment Share on other sites More sharing options...
FLlegacy Posted August 11, 2016 Share Posted August 11, 2016 If you get your arm behind the bumper through the opening in the front find where the cable connects on the latch and pull it to the driver side. You will have to do it by feel unfortunately. Link to comment Share on other sites More sharing options...
dgoodhue Posted August 12, 2016 Share Posted August 12, 2016 You might want to find another 5th Legacy in the area to look at the hood assembly with the hood open. Link to comment Share on other sites More sharing options...
A_Tang Posted September 6, 2016 Share Posted September 6, 2016 Yea, I tried that, no luck. The cable is still attacked to the interior release lever and I tried using a pair of pliers to pull on the cable, but it wouldn't budge. Did you ever figure this problem out? Went to check on the status of my power steering (which has been going in and out intermittently) and the hood won't unlatch. Seems the cable is still connected on the release level end under the dash. Link to comment Share on other sites More sharing options...
