phuzaxeman Posted February 12, 2011 Share Posted February 12, 2011 so i'm gonna have my valves adjusted (tight valves) at 92k miles. my car is only 1 owner and my daily commuter. for the most part, i have babied my car and have been good about the oil changes. other than the an axel repair, my car hasnt had any major problems. is this common in subarus? thanks just not to happy dishn out $1600. Link to comment Share on other sites More sharing options...
AShoe Posted February 13, 2011 Share Posted February 13, 2011 What is wrong with it? Sounds like a mechanic that wants some $$$ to me. Link to comment Share on other sites More sharing options...
phuzaxeman Posted February 13, 2011 Author Share Posted February 13, 2011 misfire on 2. couldn't find the prob after ruling out injectors, sparks, and coils. they said there's no clearance in the valves. Link to comment Share on other sites More sharing options...
AShoe Posted February 13, 2011 Share Posted February 13, 2011 I would try to find a reputable subaru mechanic in the local sections. It sounds like your mechanic is just taking shots in the dark. In all my reading on here I don't remember hearing about a missfire being caused by "tight valves". Link to comment Share on other sites More sharing options...
phuzaxeman Posted February 13, 2011 Author Share Posted February 13, 2011 I would try to find a reputable subaru mechanic in the local sections. It sounds like your mechanic is just taking shots in the dark. In all my reading on here I don't remember hearing about a missfire being caused by "tight valves". my mechanic couldnt figure out what was wrong. the car is at the largest subaru service in houston (gillman). Link to comment Share on other sites More sharing options...
AShoe Posted February 13, 2011 Share Posted February 13, 2011 Hopefully someone with a little more experience with this problem will chime in. IIRC missfires in cyl 2 are sometimes due to the design of the intake causing that cyl to get more air than the others. A good tune might solve your problems better than anything else. Link to comment Share on other sites More sharing options...
Underdog Posted February 13, 2011 Share Posted February 13, 2011 If your valve clearance is too tight it can result in a burnt exhaust valve which could definitely cause some misfires. A leak-down check could isolate the cylinder. The Crimson Dynamo Link to comment Share on other sites More sharing options...
phuzaxeman Posted February 13, 2011 Author Share Posted February 13, 2011 i believe the valve wasnt burnt but if the valve continues to be too tight, it will cause a burnt valve. Link to comment Share on other sites More sharing options...
