urdrwho Posted November 7, 2013 Share Posted November 7, 2013 At one time did I read that you can remove a fuse to disable the AWD on a 95 Legacy or 97 Outback? If it is true, why couldn't / wouldn't the fuse be removed in the summer when you don't need AWD? Link to comment Share on other sites More sharing options...
Grimmrican Posted November 7, 2013 Share Posted November 7, 2013 Every Subaru that is automatic (only) does it have the FWD fuse. The purpose for this fuse is if u need to tow the vehicle or have a blown tire. The whole point is if oh have to do either of these it'll prevent u blowing ur trans or rear diff Link to comment Share on other sites More sharing options...
urdrwho Posted November 7, 2013 Author Share Posted November 7, 2013 Thanks for the info. I wonder how many get towed without disabling the fuse. Probably more than we care to consider. Every Subaru that is automatic (only) does it have the FWD fuse. The purpose for this fuse is if u need to tow the vehicle or have a blown tire. The whole point is if oh have to do either of these it'll prevent u blowing ur trans or rear diff Link to comment Share on other sites More sharing options...
lockmedic Posted November 7, 2013 Share Posted November 7, 2013 It's not so much for towing with 2 wheels on the ground---that's still a bad idea. . . it's more for running a spare that's not the same size as the other 3 for a short period of time if needed. Running in FWD mode will not save you any in fuel economy as you're still spinning all those shafts & bearings & gears from the extension housing all the way back to each wheel. If you could find a way to make lockout hubs for the rear wheels you might save a bit, but that's a very long way to go to gain 2-3 mpg. Link to comment Share on other sites More sharing options...
Grimmrican Posted November 8, 2013 Share Posted November 8, 2013 Yea my 5mt or any for that matter does not come with a fuse option. In which I had to put it on a flat bed and tow her home Link to comment Share on other sites More sharing options...
Zues Marine Posted November 8, 2013 Share Posted November 8, 2013 disconnecting the rear of the 5mt driveline is pretty easy to do if you cant get a flatbed Link to comment Share on other sites More sharing options...
Grimmrican Posted November 8, 2013 Share Posted November 8, 2013 Not if ur lacking tools........ Believe me I thought of it Link to comment Share on other sites More sharing options...
Zues Marine Posted November 8, 2013 Share Posted November 8, 2013 If you cant find a pair of 12mm wrenches somethings wrong witchu, lol Link to comment Share on other sites More sharing options...
Grimmrican Posted November 9, 2013 Share Posted November 9, 2013 Lol I've not a problem with tools but when u fully clean out everything in ur car including tools and spare tire, then half the day later conveniently blow a tire.... Yea good times lol Link to comment Share on other sites More sharing options...
twisty Posted November 11, 2013 Share Posted November 11, 2013 thats usually when my vehicles break. right after i put them somewhere else. Link to comment Share on other sites More sharing options...
silverone Posted November 13, 2013 Share Posted November 13, 2013 I'm getting ready to tow an outback with the 5 MT so are you guys saying I can't tow it with the rear wheels on the ground even in neutral? Link to comment Share on other sites More sharing options...
vr4 Posted November 14, 2013 Share Posted November 14, 2013 I'm getting ready to tow an outback with the 5 MT so are you guys saying I can't tow it with the rear wheels on the ground even in neutral? You can only if you drop the driveline going to the rear diff. Link to comment Share on other sites More sharing options...
Zues Marine Posted November 14, 2013 Share Posted November 14, 2013 precisely disconnecting the rear of the 5mt driveline is pretty easy to do if you cant get a flatbed Link to comment Share on other sites More sharing options...
lockmedic Posted November 14, 2013 Share Posted November 14, 2013 I'm getting ready to tow an outback with the 5 MT so are you guys saying I can't tow it with the rear wheels on the ground even in neutral? Not if you want to have a functional transmission when you get where you're going. As zeus and others have said, disconnect the driveshaft from the rear diff. 4 bolts/nuts, and the bolts are captive. All you need is a 12mm wrench, although it helps to have someone to set/release the parking brake to hold the driveshaft while you're breaking the nuts loose. That is, assuming you can't be bothered to crawl out from under the car and do it yourself, or just bring a prybar or something to stick in the U-joint and hold it. Link to comment Share on other sites More sharing options...
twisty Posted November 14, 2013 Share Posted November 14, 2013 or just bring a prybar or something to stick in the U-joint and hold it. i have a 20" long flat head screw driver i use for that. makes it much easier. some of the smaller vehicles are almost too small to get it inside the U joint, but it hasnt left me hanging yet. Link to comment Share on other sites More sharing options...
silverone Posted November 14, 2013 Share Posted November 14, 2013 So you move the car with all the wheels on the ground in neutral it's OK. I can see the issue now you can actually pull the car I'm assuming without damage. Thanks for the clarification I'm going to have to check PO of the car I bought how he got it to the location it's currently at. If he's honest with me I only put a deposit on the car if he got it to its current location on a tow dolly I might have a problem. Thanks to everyone who commented and I apologize for hijacking the thread. Link to comment Share on other sites More sharing options...
