99subarulegacyoutback Posted October 13, 2010 Share Posted October 13, 2010 I need to know how to tightin my E-brake it only works very little i can barely feel it brake at all so if i can get a tutorial on how to it would be great thanks all Link to comment Share on other sites More sharing options...
Zues Marine Posted October 13, 2010 Share Posted October 13, 2010 Remove the center console. Loosen the top 10mm nut. Tighten the second 10mm nut until the e-brake tightens to your liking. Tighten the second 10mm nut on top of it. Replace the center console. Link to comment Share on other sites More sharing options...
99subarulegacyoutback Posted October 13, 2010 Author Share Posted October 13, 2010 im talking bout the brakes it self it dont even slow the car down at all Link to comment Share on other sites More sharing options...
subikid90 Posted October 13, 2010 Share Posted October 13, 2010 That does. It s a cable so when you tighten it it will tighten the brakes. You might want to make sure your ebrake doesnt need new shoes. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
99subarulegacyoutback Posted October 13, 2010 Author Share Posted October 13, 2010 I just put all new brakes all around bout a month ago Link to comment Share on other sites More sharing options...
subikid90 Posted October 13, 2010 Share Posted October 13, 2010 The rear brake are a hybrid system. The brakes use the rotor and they parking brake uses a drum setup. You can see it if you pull the rear rotors off and then check the condition of the shoes. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
d2b2 Posted November 23, 2010 Share Posted November 23, 2010 Any tips on how to actually do it? On my '90 the bolt kind of flexes and there isn't enough width in the center console access hole to actually turn the nut... Thanks for any help!! Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 25, 2010 I Donated Share Posted November 25, 2010 Since a few people have given you bogus info, I'll chime in with my thoughts. I'm ASE certified so I do know what I'm talking about. Like it was said prior your rear brakes have both drum and disk. Your e-brake is a drum system, and your normal brakes are disk. To PROPERLY adjust your e-brake, you have to remove your caliper, pads, machine bracket, and rotor on each rear wheel. Once you have that done, you will see a drum brake setup right behind the hub (where the lugnuts are). If you look on the bottom of it, there will be a cylinder going between each of the two shoes. In the middle of the cylinder is a ribbed disk. Use a flat head screwdriver and spin the ribbed disk. This will adjust the shoes in and out. Turn it a little bit, then put the rotor back on. If it still spins easily, remove the rotor and repeat. Once you get some resistance, that side is adjusted right. Move onto the other side and do the same thing. This is how you PROPERLY adjust your e-brake. The cable method works for a stretched out e-brake cable, but 99% of the time this is not the problem. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
