OhBe1 Posted August 4, 2006 Share Posted August 4, 2006 It's gotten to the point where my wife's neck hurts. Any suggestions? Is the '05 different & would it fit? Any recommended upholstery shops in MD? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
htewam Posted August 4, 2006 Share Posted August 4, 2006 My wife has a similar complaint. I haven't tried this yet on the Subaru (we just got it last night) but it worked on the last 3 cars that I tried it on. Just try to remove the headrest and turn it around. You might have to mess a bit with the detents but it should drop down okay. Most of the headrests these days have a slightly different profile when mounted forwards or backwards... probably not as much protection but still more then adequate. Good luck. Link to comment Share on other sites More sharing options...
laz Posted August 4, 2006 Share Posted August 4, 2006 Wow, and I always thought mine was not forward enough. You should sit on a BMW, but then again those have the option to move back and forth. I love how those headrests hold your head. X --- Link to comment Share on other sites More sharing options...
Deer Killer Posted August 4, 2006 Share Posted August 4, 2006 My head never touches the thing.. It's nearly useless. Are you sure your whiplash protection didn't go off? Link to comment Share on other sites More sharing options...
kanoswrx Posted August 4, 2006 Share Posted August 4, 2006 I noticed the 06 2.5i seats are different then the 05/06 GT seats, the headrest is a bit bigger and a little more forward. Unfotunetly I don't think their is a way to adjust it. Link to comment Share on other sites More sharing options...
dammitjim Posted August 4, 2006 Share Posted August 4, 2006 lean the seat back further? Link to comment Share on other sites More sharing options...
OhBe1 Posted August 4, 2006 Author Share Posted August 4, 2006 Leaning the seat back more than usual works for me, but not for her. And it's her car, I'm just the mechanic & test driver. Also tried reversing the headrest, that was like having none! And the rears from out old '98 swapped to the front in the '06 were also too small. Hmmm...maybe using the rears, but adding a bit of foam... And yes, supposedly there were significant changes from '05 to '06, because of a bad safety report. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
dammitjim Posted August 4, 2006 Share Posted August 4, 2006 If you can take the cover off an electric knife works great for shaping foam. Link to comment Share on other sites More sharing options...
OhBe1 Posted August 4, 2006 Author Share Posted August 4, 2006 Well, that leads me to the upholsterer. No zipper or velcro. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
vet Posted August 5, 2006 Share Posted August 5, 2006 At least on the 05's you don't need an upholsterer. There is a plastic strip on the bottom that secures the upholstery. Just slide it off. Link to comment Share on other sites More sharing options...
OhBe1 Posted August 5, 2006 Author Share Posted August 5, 2006 P 1-6 of the owners manual mentions the Active Head Restraint, but nothing about resetting it. Apparently '05's had it, and then it was "improved" for '06: http://www.iihs.org/ratings/head_re...nts.aspx?subaru Making its performance change from "Acceptable" to "Good". Of course, it now causes neck pain... So, vet's comment above indicates the '05 headrest is different; Anyone nearby want to try a comparison? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
ilh Posted August 5, 2006 Share Posted August 5, 2006 Any photos of what this looks like? Link to comment Share on other sites More sharing options...
OhBe1 Posted August 9, 2006 Author Share Posted August 9, 2006 Like this: 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Deer Killer Posted August 9, 2006 Share Posted August 9, 2006 lol.. that looks like the whiplash protection system.. Has the car been in an accident? unreported? Link to comment Share on other sites More sharing options...
OhBe1 Posted August 9, 2006 Author Share Posted August 9, 2006 Bought new, no accidents. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Deer Killer Posted August 9, 2006 Share Posted August 9, 2006 yeah, well sometimes new doesn't mean new. Link to comment Share on other sites More sharing options...
HansGT Posted August 9, 2006 Share Posted August 9, 2006 turn them around....see if they fit. Link to comment Share on other sites More sharing options...
Garandman Posted August 9, 2006 Share Posted August 9, 2006 At least on the 05's you don't need an upholsterer. There is a plastic strip on the bottom that secures the upholstery. Just slide it off. Ditto 06 AFAIK. I'll look at mine tonight since they're off the car. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
dtmenace Posted August 9, 2006 Share Posted August 9, 2006 if you raise the hr up a bit, her head may fit more comfortably in the subtle cut-out area. Link to comment Share on other sites More sharing options...
marcocb8 Posted August 10, 2006 Share Posted August 10, 2006 there is an easy fix for that, just take out the headrest and put it on the floor, then get some visegrip pliers and bent the metal pipes a little, i have done that, and it got rid of my nek pains. Link to comment Share on other sites More sharing options...
marcocb8 Posted August 10, 2006 Share Posted August 10, 2006 also, make sure that you put the pliers on the end of the pipes, and put something under the spot were you want the bend close to the upholstry. I used the edge of the sidewalk. It takes some force but it works. Link to comment Share on other sites More sharing options...
Opie Posted August 11, 2006 Share Posted August 11, 2006 If you feel the headrest are to far forward the seat is not adjusted properly, it usually means the seat is too low and the seatback is too far forward to make up the difference. Have your wife put the seatback way back, then adjust the seat to the highest setting that feels comfortable for your wife, move the seat forward of backward to the most comfortabnle setting for your wife and then as the very last step move the seatback forward until it is comfortable. At this point the headrest should not be touching the back of your wife's head. If it is the seat is still to low. So far every customer that has complained to me about the headrests being to far forward has tried this and has then been very happy with the seat comfort. Link to comment Share on other sites More sharing options...
OhBe1 Posted August 11, 2006 Author Share Posted August 11, 2006 If you feel the headrest are to far forward the seat is not adjusted properly, it usually means the seat is too low and the seatback is too far forward to make up the difference..... I'll put her on to this process. But I think the seat's already high. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
OhBe1 Posted August 11, 2006 Author Share Posted August 11, 2006 also, make sure that you put the pliers on the end of the pipes, and put something under the spot were you want the bend close to the upholstry. I used the edge of the sidewalk. It takes some force but it works. I've considered putting them in a vice, but I think they are solid, not hollow. BTW, they're 10mm in diameter, centers 150mm apart. EDIT - OK, they're hollow. Hard to tell if my first attempt to bend them did anything. Stay tuned... 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
OhBe1 Posted August 14, 2006 Author Share Posted August 14, 2006 OK, we've done both - she's adjusted the seat a bit & I straightened the curved headrest supports. So far, she's happier. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
