outback_wagon805 Posted March 4, 2012 Share Posted March 4, 2012 OK I was think about this after seeing some of the prices for a single fog light on eBay. Should I go with the original or with so Hella. Fog lights. What is your opinion if you had any of the below lights. Thank you Link to comment Share on other sites More sharing options...
Stang70Fastback Posted March 6, 2012 Share Posted March 6, 2012 Lol. You've posted this in the wrong section, but hopefully the mods can move it. I've got a set of PIAA 520 ATPs in mine. They fit just fine, however you have to drill a hole in the bumper beam to mount them. not terribly difficult. The only issue I have, personally, is that adjusting them is a PITA. You have to take the headlight out, reach down and slowly unscrew the bolt with a wrench that barely fits in that space. Take the light out, loosen the nut on the side, adjust them slightly, retighten the nut, but them back in the car, tighten the main bolt, then start over if it's still not right. And the amount that you tighten that bolt also affects their adjustment. When all is said and done though, they look good! The PIAA set was like $200 though, so that might defeat the purpose of this thread... http://farm7.staticflickr.com/6102/6274803910_1a939af6fa_b.jpg http://farm7.staticflickr.com/6019/6274805244_c9b89ab6a8_b.jpg http://farm7.staticflickr.com/6019/6274285895_68c79ef4a6_b.jpg http://farm7.staticflickr.com/6171/6274272231_d312c4406c_b.jpg Link to comment Share on other sites More sharing options...
