bpow35 Posted April 6, 2015 Share Posted April 6, 2015 So I have a wrecked 2006 5mt Lgt. I purchased a rolling chassis 05 5eat Lgt. I want to swap my engine and transmission over to this car. Can I use the trans controller from the manual trans car and not have to pull the whole under dash wiring harness? Also, can I just wire in my neutral safety switch to the preexisting wiring harness? should I use my dashboard and gauge cluster as well? any help is appreciated Link to comment Share on other sites More sharing options...
Max Capacity Posted April 6, 2015 Share Posted April 6, 2015 Talk with Dave Brady at http://www.enhancedstreetperformance.com/ He was one of the first to do this. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted April 6, 2015 Share Posted April 6, 2015 In for the LOLZ. Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted April 7, 2015 Share Posted April 7, 2015 after my radiator cracked i looked for an upgrade naturally. afaik there is a trans line going into it i think to help cool the 5eat fluid. every aftermarket rad i found said id need and external cooler. i simply stayed with stock since the car has no cooling problems with stock rad. i dont know what else you are saying. sorry. Link to comment Share on other sites More sharing options...
MrTris Posted April 7, 2015 Share Posted April 7, 2015 He's saying he wants to make his new 5EAT car a 5MT with the parts left over from his wrecked 5MT, hopefully without having to mess with all the electronics, take out the dash, etc. You'll have to take out the dash, the cluster.. The whole bit. Basically transferring your old car's electronics over to the new one. If it were easy to do, don't you think we'd have threads with pictorial walkthroughs? Link to comment Share on other sites More sharing options...
Phillip J. Fry Posted April 7, 2015 Share Posted April 7, 2015 oh ok. like when 2.5i guys ask what turbo kit is available the day after they buy their car? seems like waaaay too much work. what about the center diff? vdc vs lsd? Link to comment Share on other sites More sharing options...
bpow35 Posted April 7, 2015 Author Share Posted April 7, 2015 So far I've gotten the dash out of both cars and now working on putting the one from my manual trans car in. Just decided to strip the shell completely and move everything over piece by piece. I know everything on my wrecked car is good so I can't see why it wouldn't work in the other car. I also got the pedal assembly out of both cars and test fit it and that shouldn't be a problem. Anything else anyone can think of that would stop me? Link to comment Share on other sites More sharing options...
MrTris Posted April 7, 2015 Share Posted April 7, 2015 So far I've gotten the dash out of both cars and now working on putting the one from my manual trans car in. Just decided to strip the shell completely and move everything over piece by piece. I know everything on my wrecked car is good so I can't see why it wouldn't work in the other car. I also got the pedal assembly out of both cars and test fit it and that shouldn't be a problem. Anything else anyone can think of that would stop me? You're gonna have to basically move the entire body and engine wiring harness, in addition to some more engine bay work, like moving the clutch slave and master cylinder. Also the trans mounts are different. Now's a great time to get the Group N package if you haven't already -- should be about $200 for the engine, trans and pitch stop. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 7, 2015 Share Posted April 7, 2015 While the 5mt is out...think about Moore Performance Blast Plates. How old was the clutch ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted April 7, 2015 Share Posted April 7, 2015 While the 5mt is out...think about Moore Performance Blast Plates. How old was the clutch ? Good one! That's a big thing to have, especially if you want to ensure a long(er) life with your 5MT. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 7, 2015 Share Posted April 7, 2015 Hey OP want to buy a LWFW ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
discojon Posted April 7, 2015 Share Posted April 7, 2015 OP, I looked into this extensively a year or so ago. Trust me when I say, it's not worth it, and you will never get done right. It may well run, but you will be plagued by electrical gremlins and errors. In short, you will need: -Complete wiring harness -ECU -Complete dash -Complete steering column -pedal box / all attachments -custom fabricated transmission x-member -rear diff -driveshaft -Transmission - Link to comment Share on other sites More sharing options...
MrTris Posted April 7, 2015 Share Posted April 7, 2015 OP, I looked into this extensively a year or so ago. Trust me when I say, it's not worth it, and you will never get done right. It may well run, but you will be plagued by electrical gremlins and errors. In short, you will need: -Complete wiring harness -ECU -Complete dash -Complete steering column -pedal box / all attachments -custom fabricated transmission x-member -rear diff -driveshaft -Transmission - Now, wait a minute. Remember, he's doing a AT to MT swap with a donor. He's got an entire MT car at his disposal -- Much easier. I think it'll work. Link to comment Share on other sites More sharing options...
c-lo Posted April 7, 2015 Share Posted April 7, 2015 is there anyway I can convert my wagon into a sedan? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
keenster Posted April 7, 2015 Share Posted April 7, 2015 5eat are stout! just get the hex mod for your auto and call it a day. and if you're rough on the car then do the differential needle bearings to bushing mod. hex mod http://legacygt.com/forums/showthread.php/5eat-valve-body-upgrades-finally-164484.html?t=164484&highlight=hex+mod install for bushings http://legacygt.com/forums/showthread.php/installing-hexmods-center-differential-bulletproof-bushings-164597.html Link to comment Share on other sites More sharing options...
MrTris Posted April 8, 2015 Share Posted April 8, 2015 5eat are stout! just get the hex mod for your auto and call it a day. and if you're rough on the car then do the differential needle bearings to bushing mod. hex mod http://legacygt.com/forums/showthread.php/5eat-valve-body-upgrades-finally-164484.html?t=164484&highlight=hex+mod install for bushings http://legacygt.com/forums/showthread.php/installing-hexmods-center-differential-bulletproof-bushings-164597.html Also advice worthy of consideration. OP, how set are you on a third pedal? Yes, I understand you want to be cool and row gears, but, honestly, the 5EAT is a great car, too. You could just drop in your motor and be on your way with no hassle. There's a lot to be said for a stomp-n-go. Link to comment Share on other sites More sharing options...
bpow35 Posted April 8, 2015 Author Share Posted April 8, 2015 The clutch has about 25k on oem replacement. The engine and trans are solid. But the trans crossmember from my manual car looks like it has the same bolt pattern. Thanks for the help Link to comment Share on other sites More sharing options...
JayInVA Posted April 8, 2015 Share Posted April 8, 2015 is there anyway I can convert my wagon into a sedan? And I want to convert my sedan to a wagon. I think we just have to swap trunk lids. Let's do it. Link to comment Share on other sites More sharing options...
