555LGT Posted September 30, 2014 Share Posted September 30, 2014 Hi Guys, Was wondering if you ever encounter this before? No matter if it's warm or cold out this happens. It's hard to reproduce to the Mechanic as the car needs to sit or cooled for at least 1+ hour, and even by then it's a 50/50 chance it may not occur. Here's a link: http://vocaroo.com/i/s0WuZa0dZw9z The sound occurs around 0:16sec in the link Here's some info. about the car; '07 Legacy GT Limited - 5mt - US Specd (previous owner brought it over from Nevada, US to Toronto, Canada) - 140k - stage 1.5? Thanks in advance, Link to comment Share on other sites More sharing options...
555LGT Posted September 30, 2014 Author Share Posted September 30, 2014 Wow nobody can identify this sound? or had this problem before? Link to comment Share on other sites More sharing options...
bluesuby Posted October 1, 2014 Share Posted October 1, 2014 I think most of us have heard the screech/chirp from the starter in cold weather. Honestly, your noise sounds like a lawn mower. Link to comment Share on other sites More sharing options...
555LGT Posted October 1, 2014 Author Share Posted October 1, 2014 Good observation, i think all subies sound like lawn mowers.. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 1, 2014 Share Posted October 1, 2014 Can't view video here at work. Is it the start that is hanging up ? lots of these cars do that. There is a sticky up top about how to grease the shaft. http://legacygt.com/forums/showthread.php/diy-starter-repair-remove-disassemble-grease-reinstall-w-pics-218329.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
555LGT Posted October 3, 2014 Author Share Posted October 3, 2014 Can't view video here at work. Is it the start that is hanging up ? lots of these cars do that. There is a sticky up top about how to grease the shaft. http://legacygt.com/forums/showthread.php/diy-starter-repair-remove-disassemble-grease-reinstall-w-pics-218329.html Oh the link is not a video, it's a audio link. Yeah it starts fine, no issue or any hesitations. Just that weird sound like a moving a metal table in a room sound... I'll check the link. Bless you bro! I didn't think of that to be the shaft.. i will investigate this weekend. Thanks for the suggestion! I'll update this thread when I have a chance on my outcome. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 3, 2014 Share Posted October 3, 2014 Yea, my 09 Spec B starter hangs for a second after I turn the key to run. Did it today, it's 40F this AM, when its warm it doesn't make the sound. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
555LGT Posted October 13, 2014 Author Share Posted October 13, 2014 Yea, my 09 Spec B starter hangs for a second after I turn the key to run. Did it today, it's 40F this AM, when its warm it doesn't make the sound. Ok, here's the update. I looked into the starter shaft with my mechanic, he indicated that would not be the problem since my car does start w/o issues. However the sound that is generated maybe a pump or something else ie: abs module, fuel pump etc... Is there anywhere online i can find out what is happening when the car starts? like what mechanisms is taking place upon when the car starts? So far not sure if this is a bad thing or a good thing, but I don't hear that noise anymore. Actually i do but it's very faint if you're listening very carefully. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 14, 2014 Share Posted October 14, 2014 Still haven't heard the clip. It sounds like your talking about the air pump and the fast idle for the first few seconds after a cold start up on an 07-09. That's normal. There may be a page in the back of the service manual that explains that. I know there are flow charts back there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
CircusSub Posted February 15, 2016 Share Posted February 15, 2016 I'm very new and I am unsure how exactly I should be asking questions. This was the closest thread I could find on noises that was similar to my own problem. I bought an 06 GT about a year ago at 60k and every time I turn the car on and begin to accelerate ill get a single pop noise or it sounds almost like a spring expanding. This only happens once after I start to drive then it wont happen until I turn off and start the car again and start to drive. Sometimes I don't hear it at all but it occurs almost every time. It seems to happen once ive reached around 5mph and is sometimes quiet depending on how hard I press the gas. Again sorry if this is in the wrong place or something. Link to comment Share on other sites More sharing options...
gimpydingo Posted February 15, 2016 Share Posted February 15, 2016 Zombie thread back from the dead! My LGT always makes a metallic PING when I first start backing up after sitting over night; my 97 Jetta did the same. I've put almost 50k miles on my car, not worried about the sound. Link to comment Share on other sites More sharing options...
CircusSub Posted February 16, 2016 Share Posted February 16, 2016 Haha yeah sorry I cant figure out where to make a new one. But anyways! Thank you for the reply, I figured it wasn't to serious but it makes me so paranoid. It only happens when im driving forward but ill listen better when in reverse Link to comment Share on other sites More sharing options...
gimpydingo Posted February 16, 2016 Share Posted February 16, 2016 You should just post a new thread and make a video or sound clip of the sound if possible. Just to the top of this forum and click new topic http://legacygt.com/forums/forumdisplay.php/turbo-powertrains-2-0gt-2-5gt-2-5xt-12.html Link to comment Share on other sites More sharing options...
Carlton603 Posted February 16, 2016 Share Posted February 16, 2016 Not sure if its related, but my 06 LGT makes a very brief screeching sound (lasts maybe 1/2 a second) when I start it in very cold weather. I am assuming it is the starter issue that others have posted about. Curious to see if this is the same issue you are experiencing. Link to comment Share on other sites More sharing options...
gimpydingo Posted February 16, 2016 Share Posted February 16, 2016 Not sure if its related, but my 06 LGT makes a very brief screeching sound (lasts maybe 1/2 a second) when I start it in very cold weather. I am assuming it is the starter issue that others have posted about. Curious to see if this is the same issue you are experiencing. Probably not as he is saying it's when he accelerates. Link to comment Share on other sites More sharing options...
Carlton603 Posted February 16, 2016 Share Posted February 16, 2016 Probably not as he is saying it's when he accelerates. Sorry I was referring to the OP question Dindn't realize how old this thread was. Link to comment Share on other sites More sharing options...
gimpydingo Posted February 16, 2016 Share Posted February 16, 2016 Gotcha. Yep this is def back from the dead. Might want to start your own post, since the video is gone and I don't think anyone will be posting back here any time soon. Link to comment Share on other sites More sharing options...
Carlton603 Posted February 17, 2016 Share Posted February 17, 2016 Funny you should mention that, I've been trying to record the noise with my phone but it never does it when I'm recording haha. It's really infrequent even on cold days. Also, I'm hesitant to create a new thread I like to search things to death before I do that. Don't want to get lit up from everyone for not searching lol. Link to comment Share on other sites More sharing options...
gimpydingo Posted February 17, 2016 Share Posted February 17, 2016 Also, I'm hesitant to create a new thread I like to search things to death before I do that. Don't want to get lit up from everyone for not searching lol. Almost fell out of my chair... Link to comment Share on other sites More sharing options...
