Woodstock Posted June 13, 2009 Share Posted June 13, 2009 I just Installed Perrin RSB 22mm. It worked out pretty well; however, the Reinforcement bracket is a PITA!! Do you really have to torque the 19mm bolt that holds the reinforce bracket to 129LBS per instructions? Can you go higher than that? At first, when we took the 19mm bolt to place the reinforcement bracket supplied, the black bar with the differential dropped. We jacked it up because it was heavy to lift back and bolt it up. We bolted it up, however there was a little gap on the left side between the car and the black bar, compared to the right side. I tried to torque it to 129lbs per instruction, but we couldn't do it. its was a pain.... I drove it today, big improvement over stock RSB. But I am worried that the differential will drop.... :mad: Link to comment Share on other sites More sharing options...
atc5 Posted June 13, 2009 Share Posted June 13, 2009 Toughen up! ha... I simply impacted the heck out of it. Has been fine for the last 18 months. Link to comment Share on other sites More sharing options...
Woodstock Posted June 13, 2009 Author Share Posted June 13, 2009 well used an air drill/compressor, but there is still a gap. Then we used a Torque bar, it would just snap, gap remains. Did the same thing with a breaker bar. Then we air drilled/compressor the heck out of it. guess what? the @#$% gap won't close. The compressor that we used was not that great though. I didn't check what it looked like before we took it down. Link to comment Share on other sites More sharing options...
vinnig Posted June 14, 2009 Share Posted June 14, 2009 mine looks like this. done professionally to spec. Link to comment Share on other sites More sharing options...
Woodstock Posted June 14, 2009 Author Share Posted June 14, 2009 ^ when you jack up the car, there is a little gap maybe a dime might fit in the top part of the bracket that looks like a rubber. Everything is fine except that. Link to comment Share on other sites More sharing options...
PhillyWilly Posted June 14, 2009 Share Posted June 14, 2009 i didn orque mine. torque wrench wouldnt fit in there. tighted as much i could with socket. no worried about it. just go back and check on it later to make sure it didnt loosen. Link to comment Share on other sites More sharing options...
scoobydoobie Posted June 15, 2009 Share Posted June 15, 2009 so is a perrin reinforcement bracket basically the same thing as a cobb hd rsb mount? Link to comment Share on other sites More sharing options...
Woodstock Posted June 16, 2009 Author Share Posted June 16, 2009 i guess so. Link to comment Share on other sites More sharing options...
Woodstock Posted June 16, 2009 Author Share Posted June 16, 2009 i didn orque mine. torque wrench wouldnt fit in there. tighted as much i could with socket. no worried about it. just go back and check on it later to make sure it didnt loosen. I will check it when I rotate the tires at 15k. 9k at the odo. Link to comment Share on other sites More sharing options...
NutBucket Posted June 19, 2009 Share Posted June 19, 2009 Did you use jack stands or ramps? Link to comment Share on other sites More sharing options...
Woodstock Posted June 21, 2009 Author Share Posted June 21, 2009 I used jack stands Link to comment Share on other sites More sharing options...
08Legacy08 Posted September 11, 2009 Share Posted September 11, 2009 I think by using jack stands, when you pulled the subframe bolt out, it allowed the crossmember to drop enough to be cockeyed. I think you're talking about the gap between the car body and crossmember piece right? If so, you might want to roll it up on ramps, loosen both sides a tiny bit to allow the cross member to level and then use an impact gun to tighten each side, pulling the crossmember back up level. Just my .02 Link to comment Share on other sites More sharing options...
GTTuner Posted September 13, 2009 Share Posted September 13, 2009 No abnormal noises? Pics please. Link to comment Share on other sites More sharing options...
Woodstock Posted September 14, 2009 Author Share Posted September 14, 2009 I will put it in a ramp then use an impact gun to tighten it. The only noise I hear is a high pitch sound when I let of the gas. It is probably the sway bar not being greased enough? Link to comment Share on other sites More sharing options...
scoobydoobie Posted September 14, 2009 Share Posted September 14, 2009 why would the swaybar make noise when you let off the gas? Link to comment Share on other sites More sharing options...
Woodstock Posted September 15, 2009 Author Share Posted September 15, 2009 its a really high pitch sound. it will last for half a second as soon as I let of the gas. Link to comment Share on other sites More sharing options...
wpmarky Posted September 15, 2009 Share Posted September 15, 2009 Is it a whine or a hiss? The only sound the rear way can make is a rattle. A whine might be drivetrain related, and a hiss might be a exhaust or boost leak. Link to comment Share on other sites More sharing options...
Woodstock Posted September 15, 2009 Author Share Posted September 15, 2009 its more like 2 thin swords that are being swipped. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted September 16, 2009 Share Posted September 16, 2009 its more like 2 thin swords that are being swipped. IDK about you but I think that sound is awesome [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Woodstock Posted September 17, 2009 Author Share Posted September 17, 2009 LOL! sssswwwiing! Link to comment Share on other sites More sharing options...
