mass-hole Posted September 8, 2012 Share Posted September 8, 2012 My search-fu must not be honed in today, but i swear i had seen a thread with a suggested "performance" alignment for stock suspension cars. Can anyone point me to that? Thanks! Link to comment Share on other sites More sharing options...
iggybdawg Posted September 10, 2012 Share Posted September 10, 2012 I'd do max negative camber and 0 toe (stock, the rears are only toe adjustable). If you get a good shop, you should be able to get it slightly past -1 degree. Camber bolts are cheap and can take it further. Link to comment Share on other sites More sharing options...
whitetiger Posted September 10, 2012 Share Posted September 10, 2012 yes to max out stock negative camber. Link to comment Share on other sites More sharing options...
DeleriousZ Posted September 10, 2012 Share Posted September 10, 2012 Toe out in the front will improve steering response feel, but if you go too far it will destroy your tires. (check for feathering of the tread) Link to comment Share on other sites More sharing options...
sjwelna Posted September 10, 2012 Share Posted September 10, 2012 I just had an alignment done on my '08 with Epic springs/Koni inserts. Max he could get was -0.8* front camber, zeroed out toe on all 4 corners, and rear camber was static at -0.9*RL and -1.2* RR. I could tell a difference as when it went in front camber was ~-0.4* and the toe on the left side was definitely out. This is with all stock hardware. YMMV. -Steve Link to comment Share on other sites More sharing options...
Dbl_D718 Posted September 10, 2012 Share Posted September 10, 2012 Related thread jack: I just installed the Whiteline rear camber kit and have them eyeballed pretty close to each other right now but need to get them actually aligned. Should a chain shop like Sears or Meineke be able to figure out how to adjust the rear, or is it worth the extra $100 for the local performance shop to do it? MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
whitetiger Posted September 10, 2012 Share Posted September 10, 2012 go to a performance shop. all the chain shop wants to do is set your front toe and send you out the door Link to comment Share on other sites More sharing options...
jamal Posted September 11, 2012 Share Posted September 11, 2012 Related thread jack: I just installed the Whiteline rear camber kit and have them eyeballed pretty close to each other right now but need to get them actually aligned. Should a chain shop like Sears or Meineke be able to figure out how to adjust the rear, or is it worth the extra $100 for the local performance shop to do it? No way in hell will an average alignment shop be able to figure that out. They can't even figure out a stock car most of the time. Needs to be a performance alignment shop that knows Subarus. Which is ridiculous because it's really not that hard. As far as numbers go, -1.5 to -2 is a good range for the front, -1 or slightly more is a good place to be in the rear. Getting that much front camber needs some extra work like bolts or slotting the lower struts. Definitely worth it though to get a little more front camber. Link to comment Share on other sites More sharing options...
CapnJack Posted September 11, 2012 Share Posted September 11, 2012 So if one were to change struts on the front, would an alignment really be needed? The only thing that should change is camber. If one were to max out the stock hardware, would that be sufficient or would an alignment be recommended, just to check things out?? Link to comment Share on other sites More sharing options...
jamal Posted September 11, 2012 Share Posted September 11, 2012 When the camber changes the toe also changes, so yes you need an alignment. Link to comment Share on other sites More sharing options...
Heedz Posted September 12, 2012 Share Posted September 12, 2012 Maxed the front out to -1.5 the rear to -1.0 with the whiteline kit and achieved 7.3-4 degrees of caster and zero toe front and slight every so slight toe out in the rear. Car has great turn in and rotation out of the turn. Link to comment Share on other sites More sharing options...
FPerron Posted September 12, 2012 Share Posted September 12, 2012 Makes no sense to mess with stock alignment unless you are tracking the car. If you are tracking the car, adjust camber to the specs suggested by the tire manufacturer -this will mean mega negative camber (-2 to -3). To get this, you probably need coilovers and adjustable control arms in the rear. Link to comment Share on other sites More sharing options...
underground000 Posted September 12, 2012 Share Posted September 12, 2012 IIRC a vendor on here posted these when I was looking. you are going to need a front/rear camber bolts camber front -2.0 rear -1.5 toe 0 camber wear wont be very noticeable until the last 30% of tread life, and with the -2 deg camber there was not much camber wear. some say run -1.5 front and -1 rear camber and 0 toe 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
TcDavis Posted September 18, 2012 Share Posted September 18, 2012 Related thread jack: I just installed the Whiteline rear camber kit and have them eyeballed pretty close to each other right now but need to get them actually aligned. Should a chain shop like Sears or Meineke be able to figure out how to adjust the rear, or is it worth the extra $100 for the local performance shop to do it? Which kit? Found 2 Tc Davis Link to comment Share on other sites More sharing options...
Dbl_D718 Posted September 19, 2012 Share Posted September 19, 2012 KCA399 What'd you find? I wasn't aware they made another option besides the adjustable arms. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
jamal Posted September 19, 2012 Share Posted September 19, 2012 Yeah there's an offset bushing for the upper arm or the link set which replaces the toe and camber arms. Link to comment Share on other sites More sharing options...
whitetiger Posted September 19, 2012 Share Posted September 19, 2012 if you use the offset bushing in conjunction with the arms, you can actually increase the rear track width a little. Link to comment Share on other sites More sharing options...
.Catalyst. Posted September 19, 2012 Share Posted September 19, 2012 Maxed the front out to -1.5 the rear to -1.0 with the whiteline kit and achieved 7.3-4 degrees of caster and zero toe front and slight every so slight toe out in the rear. Car has great turn in and rotation out of the turn.That's similar to my alignment specs and really happy with the car's handling. I'm at: Camber -1.5F/-1.1R Toe 0F/0R Caster 6.4 (that was maxed out with my car's setup and the WALK) My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
TcDavis Posted September 19, 2012 Share Posted September 19, 2012 Should i go with offset bushing, or bolt? Tc Davis Link to comment Share on other sites More sharing options...
TcDavis Posted September 19, 2012 Share Posted September 19, 2012 if you use the offset bushing in conjunction with the arms, you can actually increase the rear track width a little. What arms? Tc Davis Link to comment Share on other sites More sharing options...
jamal Posted September 19, 2012 Share Posted September 19, 2012 If you have a 2011 the parts are a little different. Cusco makes a nice adjustable LCA and then whiteline has offset bushings for the upper a-arm. Those bushings are a huge pain to install. Link to comment Share on other sites More sharing options...
TcDavis Posted September 21, 2012 Share Posted September 21, 2012 Noticed after buying the whiteline bushings for my 5th gen, it looks nothing like 4th gen:eek: so where do they go? Tc Davis Link to comment Share on other sites More sharing options...
