gear_monkey Posted January 11, 2013 Share Posted January 11, 2013 Hey folks, Spent ALL day at the shop yesterday getting Sti up and Perrin catless dp installed with tune on my 05 GT. It's a whole new car performance wise but there is no way I can handle the noise. It is way too loud in the cabin. I was told there would be a throatier rumble but this is more than I can stand. This is my daily driver/family car and I feel like I made a huge mistake. Is there any way to quite this down? If not I'm going to have to return to stock down pipe...I feel like an idiot. Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 11, 2013 Share Posted January 11, 2013 Get a catted downpipe. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
dustincredible Posted January 11, 2013 Share Posted January 11, 2013 QUIET Sold: 2006 Subaru Legacy GT Spec B #104 of 500 Link to comment Share on other sites More sharing options...
SBT Posted January 11, 2013 Share Posted January 11, 2013 Fixed. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
GTTuner Posted January 11, 2013 Share Posted January 11, 2013 I have a full catless system, not loud at all......what are you running for the mid/Y and exhaust cans? Link to comment Share on other sites More sharing options...
fahr_side Posted January 11, 2013 Share Posted January 11, 2013 Get a catted downpipe. This. High-flow cat = stock sound. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
SBT Posted January 11, 2013 Share Posted January 11, 2013 ^ With stock catback sortof. More throaty, but shouldn't be significantly louder. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
fahr_side Posted January 11, 2013 Share Posted January 11, 2013 Mine really didn't get any louder with a catted downpipe and stock catback, at least not in the cabin. Midpipe made it a little more raspy and then the EL header introduced a little drone. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
SBT Posted January 11, 2013 Share Posted January 11, 2013 Adding the Cobb HFC DP to my stock exhaust opened up the throatiness a bit, you could definitely hear more exhaust. Going to the Perrin mid/Y and Prodrive cans, really changed the tone, even with a resonator in the mid-pipe. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
gear_monkey Posted January 11, 2013 Author Share Posted January 11, 2013 I have a full catless system, not loud at all......what are you running for the mid/Y and exhaust cans? It is a Perrin catless down pipe connected to my OEM exhaust just before the y split. I have found at least a little of the problem..the dp is touching the firewall as it makes its way out of the turbo. Would a resonator be the best noise solution? My real complaint is the turbo whine that is really loud now. Link to comment Share on other sites More sharing options...
nhltfour Posted January 11, 2013 Share Posted January 11, 2013 This. High-flow cat = stock sound. yeah, with a stock cbe. I have an Invidia high flow downpipe and SPT exhaust and no drone inside the car unless I want the drone. beautiful sounding exhaust that I would reccomend Link to comment Share on other sites More sharing options...
GTTuner Posted January 11, 2013 Share Posted January 11, 2013 It is a Perrin catless down pipe connected to my OEM exhaust just before the y split. I have found at least a little of the problem..the dp is touching the firewall as it makes its way out of the turbo. Would a resonator be the best noise solution? My real complaint is the turbo whine that is really loud now. The Perrin is a terrible fit. Dump that pipe and get anything else......even a gutted OE DP. Link to comment Share on other sites More sharing options...
chimaira4deth Posted January 11, 2013 Share Posted January 11, 2013 heat wrap the dp. or dyno-mat from below Link to comment Share on other sites More sharing options...
9mm Posted January 11, 2013 Share Posted January 11, 2013 i'm running a cobb catted DP on my 12 WRX Wagon w/ stock cat-back. it sounds stock. eventually i'll get either the SPT or Greddy SP Elite CBE to get a little bit more rumble. i made the same mistake with the Invidia Q300. LOL. got a ******* ticket with it, took it off two days later. ROFL. i feel your pain. i have the Cobb SF intake + Box and Cobb Catted DP w/ a Protune from Kaizen. i'm happy with it performance wise... 249HP and 288ft pounds to the wheels... i just want a little bit more rumble.. not noise. /\__/\ (='.'=) This is Cat. Copy and paste Cat (")_(") to help him gain world domination. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 15, 2013 Share Posted January 15, 2013 Yep, my Invidia catless dp and stock exhaust on the wagon is to quiet for me. Invidia has great fitment. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
nhltfour Posted January 16, 2013 Share Posted January 16, 2013 Yeah I had no troubles at all. Even with a wrapped and sprayed downpipe only ONE of the turbo bolts was hard to get a wrench around. but other than that no complaints. max cap. get a SPT and you will have a large grin on your face Yep, my Invidia catless dp and stock exhaust on the wagon is to quiet for me. Invidia has great fitment. Link to comment Share on other sites More sharing options...
