teamafx Posted June 13, 2013 Share Posted June 13, 2013 I have been having a cylinder 2, and 4 misfire. Idle is ROCK solid with it plugged in and with it unplugged. The misfire only happens under a load. With MAF disconnected I can run and drive at any throttle without misfire. Any ideas? Link to comment Share on other sites More sharing options...
Berzerklo Posted June 13, 2013 Share Posted June 13, 2013 Any mods? Specifically any aftermarket intake? Stock tune? Link to comment Share on other sites More sharing options...
apexi Posted June 13, 2013 Share Posted June 13, 2013 Bad driver side oil control valve would be my guess with those 2 cylinders both misfiring. Link to comment Share on other sites More sharing options...
teamafx Posted June 13, 2013 Author Share Posted June 13, 2013 Oil control valve wouldnt dissapear with maf disconnected. Link to comment Share on other sites More sharing options...
teamafx Posted June 13, 2013 Author Share Posted June 13, 2013 And only mod is catback Link to comment Share on other sites More sharing options...
apexi Posted June 13, 2013 Share Posted June 13, 2013 I think it was a coincidence that the misfire disappeared with the maf disconnected, I still think OCV. Link to comment Share on other sites More sharing options...
teamafx Posted June 13, 2013 Author Share Posted June 13, 2013 Its not a coincidence. It happens that way every time. Ocv works off of oil pressure and would cause a misfire regardless of if the maf is disconnected and would not have a solid idle with no misfire present Link to comment Share on other sites More sharing options...
apexi Posted June 14, 2013 Share Posted June 14, 2013 Are there any other codes present other than the misfires? My only other thought is a vacuum leak somewhere, hopefully others will chime in with their thoughts. Link to comment Share on other sites More sharing options...
teamafx Posted June 14, 2013 Author Share Posted June 14, 2013 No other codes.....changing out maf and af sensor tomorrow Link to comment Share on other sites More sharing options...
lee07 Posted June 14, 2013 Share Posted June 14, 2013 Vacuum hose leak or disconnected behind/under the tmic Easy fix, just find the loose hose and plug it back in Link to comment Share on other sites More sharing options...
teamafx Posted June 14, 2013 Author Share Posted June 14, 2013 I have smoke tested this, no vacuum leaks Link to comment Share on other sites More sharing options...
teamafx Posted June 14, 2013 Author Share Posted June 14, 2013 also changing out af sensor did nothing Link to comment Share on other sites More sharing options...
Max Capacity Posted June 14, 2013 Share Posted June 14, 2013 Been following this...it doesn't make sense. Can you get a volt meter and test the wires for the MAF and #2 & 4 coils. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
mwiener2 Posted June 14, 2013 Share Posted June 14, 2013 How did you check for air leaks? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
teamafx Posted June 14, 2013 Author Share Posted June 14, 2013 I have a smoke machine, no air leaks at all in system, rock solid. The smoke machine also can feed air in which I did, again rock solid. Im about to just sell it for parts.....I am at a loss. With maf connected barely moves out of its own way. With it disconnected I can drive and have slight hesitation but it is infinetely better. Replaced MAF, nothing, replaced a/f sensor nothing. Link to comment Share on other sites More sharing options...
mwiener2 Posted June 14, 2013 Share Posted June 14, 2013 Having a smoke machine is one thing, using it is another.  How are you checking it for air leaks? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
teamafx Posted June 14, 2013 Author Share Posted June 14, 2013 I used the smoke machine..... Remove the air filter and it runs and drives. Wondering if this is a misrouted vac line Link to comment Share on other sites More sharing options...
mwiener2 Posted June 14, 2013 Share Posted June 14, 2013 One more try... How did you check for leaks? How did you use the smoke machine?  So now if you take your air filter off, it runs fine with the MAF connected? And you have a turbo model? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
teamafx Posted June 14, 2013 Author Share Posted June 14, 2013 I know how to use a smoke machine......been doing it for 20 years. Entire vac system was checked. Smoke did not leak, maintained pressure and machine indicated no leak. Â I got this car used and have been trying to find the route of all its issues. I never anticipated misrouted lines Link to comment Share on other sites More sharing options...
teamafx Posted June 14, 2013 Author Share Posted June 14, 2013 I need a vacuum diagram... Link to comment Share on other sites More sharing options...
apexi Posted June 14, 2013 Share Posted June 14, 2013 Best I could find http://legacygt.com/forums/showthread.php/2005-2006-lgt-colored-vacuum-routing-diagram-143225.html Link to comment Share on other sites More sharing options...
mwiener2 Posted June 14, 2013 Share Posted June 14, 2013 You have a leak at the inlet tube of the turbo. I also suspect you have a restrictive air filter. Probably dirty. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
teamafx Posted June 15, 2013 Author Share Posted June 15, 2013 Inlet tube shows no leak. Also air filter is brand new oem Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 15, 2013 Share Posted June 15, 2013 How are the brakes? Perhaps booster vacuum leak? Link to comment Share on other sites More sharing options...
teamafx Posted June 15, 2013 Author Share Posted June 15, 2013 Booster is good, brakes are great. Checked inlet to turbo, no leak. Only thing i can think of is that the lines off of intake tube are misrouted. Anyone give me a breakdown starting at the air filter forward where the ports go specifically. Link to comment Share on other sites More sharing options...
