mattg Posted April 24, 2008 Share Posted April 24, 2008 before you say they're too wide for a 7" rim, know that the guy at Americas Tire said they would fit just fine. you can also take a look at my last car, which had 17x7 factory wheels wearing Kumho 712's in 235/40-17. http://photos.imageevent.com/mattg/carstuff/MVC-001S.JPG seems to me that the shorter 235/40's would be closer to stock o.d. and offer better looks and performance. thoughts? The tires I'm getting are Yokohama S drives. They're giving me $200 trade in on my 85% RE92's. Link to comment Share on other sites More sharing options...
mattg Posted April 24, 2008 Author Share Posted April 24, 2008 sorry, I meant 225/45-17 or 235/40-17. if a mod could edit that, it would be appreciated. Link to comment Share on other sites More sharing options...
Mr. Ed Posted April 24, 2008 Share Posted April 24, 2008 i'm pretty sure that 235 40 fits...it's 235 45 that doesn't i really enjoyed the look of 225 45 myself... haven't tried 235 Link to comment Share on other sites More sharing options...
VTGT Posted April 24, 2008 Share Posted April 24, 2008 mattg, i thought you had p7's for summer use? Link to comment Share on other sites More sharing options...
mattg Posted April 24, 2008 Author Share Posted April 24, 2008 PFF7's, and they're for sale. I want to use the money for some more performance upgrades. http://photos.imageevent.com/mattg/legacygt/websize/IMG_0546.JPG Link to comment Share on other sites More sharing options...
VTGT Posted April 24, 2008 Share Posted April 24, 2008 slightly depressing. Hopefully a bigger turbo will bring you happiness. Link to comment Share on other sites More sharing options...
AirSix Posted April 24, 2008 Share Posted April 24, 2008 I did 225/45 Conti's on my stockers for a bit. They looked a bit balloonish but I think that was because of the design of the Conti's sidewall. They still look a bit tall even mounted on my 17X8's. I think if you had them on a previous car with a similar set up you've answered your own question. Bigger contact patch sounds like the best plan. I tell myself that an N/A Forester is just an STI without all the fluff like, power, handling, style, racing heritage, and curb appeal. Link to comment Share on other sites More sharing options...
nKoan Posted April 24, 2008 Share Posted April 24, 2008 I've done 225/45 on stock rims and 235/40 on aftermarket (17x8) rims (and I've even done 225/40 on 17x8 rims, not that I'd recommend that). The 235s may be closer to the stock OD, but I found that the 225 seems to make the spedo read more accurately, as it tends to read slightly high from the factory. If you are in an area where potholes might be a problem, the 225 might be a better choice for that reason. Another thing to consider, I think 235/40 might look a little weird at stock ride height. But, that's just personal opinion. Link to comment Share on other sites More sharing options...
mattg Posted April 24, 2008 Author Share Posted April 24, 2008 my ride height http://photos.imageevent.com/mattg/legacygt/large/IMG_5166.JPG these are my 225/45-17 snow tires Link to comment Share on other sites More sharing options...
mattg Posted April 24, 2008 Author Share Posted April 24, 2008 ^ any more opinions? Link to comment Share on other sites More sharing options...
BrownBoy Posted April 24, 2008 Share Posted April 24, 2008 Id probably stick with the 225/45 myself. As far as performance, I bet it would be pretty close. Since the wider tire will not sit as "stretched" <---I use this term loosely on the rim, the lower sidewall vs. the narrower 225 with a taller sidewall will not matter much. I'm sure that the higher profile, less wide tire will be cheaper also, from a cost standpoint. I've ran the stock 205s on my car, 235s on 8.5s, and now 255s on 8.5s. The narrower 235s were awesome compared to the pretty good 255s. Just my .02... Link to comment Share on other sites More sharing options...
mattg Posted April 24, 2008 Author Share Posted April 24, 2008 thanks for the input. the 235/40's are $5 more each. Link to comment Share on other sites More sharing options...
biggggant Posted April 27, 2008 Share Posted April 27, 2008 i have 225/45 sumitomo htr ZIII's and I like them and they make my speedo dead on according to my garmin nuvi Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted April 28, 2008 Share Posted April 28, 2008 I've got 225/45/17 on my stockers and enjoy the ride. Link to comment Share on other sites More sharing options...
VTGT Posted July 26, 2008 Share Posted July 26, 2008 Did you every end up installed 235/40/17's on your stock wheels? I found some hankook ice bears in 235/45/17 that I want to use as my fall/winter/spring setup on my stock wheels :-) I am thinking that will give me a good compromise between dry and cold weather handling. Link to comment Share on other sites More sharing options...
mattg Posted July 26, 2008 Author Share Posted July 26, 2008 I went with 225/45's and it's probably a good thing I did as the Yoko S-drives are wide tires. Link to comment Share on other sites More sharing options...
SBT Posted July 28, 2008 Share Posted July 28, 2008 I run MPS AS 225/45x17 on the stock rims and they look/work fine. How do you like the Yoko Ses? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
turboWagon Posted July 29, 2008 Share Posted July 29, 2008 I have potenza s03 235/40-17 on my stock rim. It fits fine and made a huge difference on the handling. Link to comment Share on other sites More sharing options...
