direavenger Posted January 17, 2007 Share Posted January 17, 2007 I just wanted to share my used oil analysis from Blackstone Labs. I went with a 5k OCI this time, but might extend it to 6k based on their recommendations. Comments or questions are welcome. The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
wukindada Posted January 17, 2007 Share Posted January 17, 2007 Been a little curious about that oil........ Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
edmundu Posted January 17, 2007 Share Posted January 17, 2007 Rumor has it, that it is PP with very, very small add pack changes. Still a pretty good oil! Nice UOA! Although the silicone seemed a bit elevated at 16 ppm? Mine have always been no higher than 13, and usually at 11 or less. I'm assuming it is the original filter? I'm currently running PP 5w-40 euro, as I can source it from a local auto parts store for a few $$$ less than GC. Link to comment Share on other sites More sharing options...
direavenger Posted January 17, 2007 Author Share Posted January 17, 2007 ^^^I noticed the higher than average silicon level too, although I'm not sure what that indicates. What contains silicon, some kind of seal? What do you mean by "original filter"? I am using oil filters from subarugenuineparts.com, and I change filters when I change the oil (duh). The filters are black, if that helps at all. The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
wukindada Posted January 17, 2007 Share Posted January 17, 2007 Been running PP 10w30 for almost a year now along with the K&N filter. very impressed with the results:) I'm not really much of a fan of K&N anymore but the welded 1"socket attachment is awesome!!! Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
direavenger Posted January 17, 2007 Author Share Posted January 17, 2007 Nice! I didn't know that there was a good substitute for the OEM filter. I think I'll change to that after my warranty expires, give the dealership less ammo should something go wrong. Any price difference between the filters? I think I paid about $6-7 each for a sixpack of OEM filters and crush washers The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
edmundu Posted January 17, 2007 Share Posted January 17, 2007 ^^^I noticed the higher than average silicon level too, although I'm not sure what that indicates. What contains silicon, some kind of seal? What do you mean by "original filter"? I am using oil filters from subarugenuineparts.com, and I change filters when I change the oil (duh). The filters are black, if that helps at all. Nah, not oil filter's, air filter. Silicon is usually found in a newly assembled engine, or one recently repaired. After sometime, say 10-15k miles, this would be gone, and now the remaing silicone seen in the oil is largely due to dirt getting past the filter. Silicone is an excellent indicator of air filtration. Now in dustier environments, it will uptick higher, so without knowing your baseline for your conditions, it is a little tougher to say. But on your next UOA, if it is still showing around the same ppm, I would change the filter. If you are paranoid, you can take a peek at the stocker, and see how dirty it is anddetermine if it needs replacement sooner than the 30k maint. interval suggestion... Link to comment Share on other sites More sharing options...
edmundu Posted January 17, 2007 Share Posted January 17, 2007 You know, I have tested a few oil filter's, and none of them did any better than another. So I go with the cheapest I can find.....:drumroll: Walmart Supertech 7317 FTW! $2.17, and I get crush washer's for under $1, which I use 2x then throw away. (They are made by Champion Labs, the same maker of M1 and K&N, Bosch...so actually a pretty good oil filter.) I have used Wix, OEM, Bosch, ST, and Purolator. They all filtered the same, and quite frankly, I think any decent(read not Fram) oil filter will do the job. I think the only true benefit to the factory oem one is that it can be run slightly longer becasue it has a few extra pleats as compared to the other's. I'm talking like 9-10k OCI's instead of 7.5-8.5k. So for anyone using 6k or less, you can easily get away with cheaper filters and not give up any quality. This works out to some savings for me as I do a lot of hwy commuting, and change my oil 4x a year or more... Link to comment Share on other sites More sharing options...
direavenger Posted January 17, 2007 Author Share Posted January 17, 2007 Oh, now I understand. Unless the dealership snuck some work past me, it is still the stock filter. I'll check it out when I get a chance. Thanks for your help! The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
wukindada Posted January 17, 2007 Share Posted January 17, 2007 My only reason for using the K&N is ease of removal;) I change the oil every 4k & I like you ed do the majority of my driving on the hwy (16k a year) So a grand total per year for oil & filter changes comes up to a meager 116.00.... That is also the only reason why I change @ 4k intervals as the PP is good for well past that Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
mickeyd2005 Posted January 17, 2007 Share Posted January 17, 2007 Good info. I'm at 12,000 miles with my stock air filter. I'll probably change my oil this weekend and get it analyzed. It will be interesting to compare the silicon levels. Link to comment Share on other sites More sharing options...
edmundu Posted January 17, 2007 Share Posted January 17, 2007 My only reason for using the K&N is ease of removal;) I change the oil every 4k & I like you ed do the majority of my driving on the hwy (16k a year) So a grand total per year for oil & filter changes comes up to a meager 116.00.... That is also the only reason why I change @ 4k intervals as the PP is good for well past that Damn, your wasting good oil! 4k? That's all? Heck, you spoil your car, I don't let mine see any earlier than 6k. I found a KD tools oil filter wrench, actually more like a claw, that works on any filter up to I believe the 5" diam. It has 3 finger's, and they rotated in or out to fit the filter, and then bite into it when you go to loosen the filter. YOu use a 3/8" square drive ext. on a rachet. It is made of hardened steel, and has yet to lose to any filter! Cost like $8 at the local auto parts store. I use the money saved on filter's, to fund my methanol needs, you know for the alky injection:icon_mrgr ! Link to comment Share on other sites More sharing options...
direavenger Posted January 17, 2007 Author Share Posted January 17, 2007 Damn, your wasting good oil! 4k? That's all? Heck, you spoil your car, I don't let mine see any earlier than 6k. I found a KD tools oil filter wrench, actually more like a claw, that works on any filter up to I believe the 5" diam. It has 3 finger's, and they rotated in or out to fit the filter, and then bite into it when you go to loosen the filter. YOu use a 3/8" square drive ext. on a rachet. It is made of hardened steel, and has yet to lose to any filter! Cost like $8 at the local auto parts store. I use the money saved on filter's, to fund my methanol needs, you know for the alky injection:icon_mrgr ! This is reassuring. I'm going 6k OCI with stock everything, and to know that you're going 6k with quite the monster setup makes me feel at ease. Speaking of which, here is a "for instance". If I got yearly UOAs done and kept records of materials purchased for my oil changes, would this cover me as far as the warranty is concerned? The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
edmundu Posted January 17, 2007 Share Posted January 17, 2007 So long as you do not exceed the 7.5k/6mth OCI , then yeah, it should be covered. It's the dated oil receipts that hold water. The UOA should help, but I'm not sure SOA would care about that....Even if it proves out the health of the engine. Link to comment Share on other sites More sharing options...
outahere Posted January 19, 2007 Share Posted January 19, 2007 .......I have used Wix, OEM, Bosch, ST, and Purolator. They all filtered the same, and quite frankly, I think any decent(read not Fram) oil filter will do the job...... Early indications seem to indicate that the new "nanofiber" types of filter media, such as Synteq from Donaldson, will offer a real improvement over what has been available for the last 20 years. We are talking about improved contaminant retention without a reduction in flow. Lots of discussion about it over at BITOG. Amsoil has started selling filters with nanofiber media, for limited applications. Link to comment Share on other sites More sharing options...
edmundu Posted January 19, 2007 Share Posted January 19, 2007 Early indications seem to indicate that the new "nanofiber" types of filter media, such as Synteq from Donaldson, will offer a real improvement over what has been available for the last 20 years. We are talking about improved contaminant retention without a reduction in flow. Lots of discussion about it over at BITOG. Amsoil has started selling filters with nanofiber media, for limited applications. Learn something new everyday! Thanks! I guess I have been neglecting BITOG... Link to comment Share on other sites More sharing options...
mach_six Posted January 19, 2007 Share Posted January 19, 2007 You know, I have tested a few oil filter's, and none of them did any better than another. So I go with the cheapest I can find.....:drumroll: Walmart Supertech 7317 FTW! $2.17, and I get crush washer's for under $1, which I use 2x then throw away. (They are made by Champion Labs, the same maker of M1 and K&N, Bosch...so actually a pretty good oil filter.) I was doing an oil change for my car and I went to Autozone and picked up some STP filters. The new Supertech looks just like it, with that light blue valve thing in the middle and even the sides both have that same drawings showing how to change the filter. I've been used 6609, is 7317 what the book recommends now? I agree these filters are cheap and plentiful and do the work. As for newer nano filters, if you keep with a 3k oil change will it make a difference? I can see if you want to go for extended use otherwise it'll just be a waste of money. Link to comment Share on other sites More sharing options...
wukindada Posted January 19, 2007 Share Posted January 19, 2007 I'm going to be switching to the Amsoil EAO12 next oil change, I'll change the filter every other change. Want to see what the test result's come back with...... Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
edmundu Posted January 19, 2007 Share Posted January 19, 2007 I was doing an oil change for my car and I went to Autozone and picked up some STP filters. The new Supertech looks just like it, with that light blue valve thing in the middle and even the sides both have that same drawings showing how to change the filter. I've been used 6609, is 7317 what the book recommends now? I agree these filters are cheap and plentiful and do the work. As for newer nano filters, if you keep with a 3k oil change will it make a difference? I can see if you want to go for extended use otherwise it'll just be a waste of money. No, the 7317 is just a smidge longer, so it can hold a touch more oil. And yeas the STP's are indeed made by Champion Labs as well. Very good filter, they are usually $1 more than Walmart's housebrand though. Link to comment Share on other sites More sharing options...
nx2000 Posted January 19, 2007 Share Posted January 19, 2007 Awesome post. I'm changing my oil in the next day or so and will be it analyzed by Blackstone Labs as well. I'm going to post the results here as well. I do lots of highway mileage and want to know how long I can extend the OCI's. Currently, I'm doing my OCI's at 6000kms (3750 miles) and am using Mobil1 5W30 and the OEM filter (white). Link to comment Share on other sites More sharing options...
sirsimon Posted January 24, 2007 Share Posted January 24, 2007 Out of curiosity: Do those of you who go 6k between oil changes change your filters more often? Link to comment Share on other sites More sharing options...
wukindada Posted January 24, 2007 Share Posted January 24, 2007 It's always a good practice to change the filter @ the same time you change the oil. Though on my next change I am switching over to the Amsoil filter & I am going to leavve it on for 2 changes & then send it in to Blackstone for analysis. Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
biz77 Posted January 27, 2007 Share Posted January 27, 2007 Out of curiosity: Do those of you who go 6k between oil changes change your filters more often? Wouldn't it be kind of difficult and messy to change your oil filter without changing the oil? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted January 27, 2007 Share Posted January 27, 2007 Actually, no. It's the same amount of mess. Two different oil compartments. Link to comment Share on other sites More sharing options...
gianspi Posted January 27, 2007 Share Posted January 27, 2007 If you are paranoid, you can take a peek at the [air filter] stocker, and see how dirty it is anddetermine if it needs replacement sooner than the 30k maint. interval suggestion... I checked my air filter at 18,000 miles, and it was completely black with a few leaves in it. No way it would last 30,000mi..that's a joke. I'm now checking it every oil change and replacing it every 10,000 miles. Small price to pay for not letting crap getting in my engine. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
