iano81 Posted February 9, 2014 Share Posted February 9, 2014 Hello, I have a 09 legacy. I am attempting to install aftermarket projector fog lights. I'd like to wire them so that they turn on when the corner lights, or tail lights turn on. Does anyone know what is the best way to do this? I appreciate the help. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted February 13, 2014 Share Posted February 13, 2014 tap the positive into the positive for the turn signal's. I'm not sure if the voltage will be enough though so check on what kind of voltage they get from that. Another thing would be a relay harness that is tapped into the turn signals so that when they are turned on it trips the relay on which then powers the lights up. The lights would be directly connected to the battery in this instance. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
iano81 Posted February 13, 2014 Author Share Posted February 13, 2014 By doing this would I be able to turn on the fogs independently from the turn signals? I like the idea of perhaps the left fog turning on as I turn left, but I also would like to have them on in the dark when I am not turning. Link to comment Share on other sites More sharing options...
Kevin622 Posted February 13, 2014 Share Posted February 13, 2014 You would tap into the power wire of the parking lights. When you turn on your parking lights the fogs would also come on. Link to comment Share on other sites More sharing options...
MrTris Posted February 17, 2014 Share Posted February 17, 2014 Why not complete the independent fog wiring mod (see walkthroughs) and just replace the fogs? Do you really want your foglights on ALL the time? Link to comment Share on other sites More sharing options...
Kevin622 Posted February 18, 2014 Share Posted February 18, 2014 Thats what i would do is run it to its own switch so you can turn them on and off whenever. Link to comment Share on other sites More sharing options...
MJC784 Posted October 12, 2015 Share Posted October 12, 2015 just out of curiosity what projector fogs did you use? I have an 09 LGT and id like to do the same Link to comment Share on other sites More sharing options...
